Old 06-13-2005, 02:53 AM
poldo poldo is offline
Default undipped meaning
Hi all,
can someone please explain to me the exact meaning of "undipped mix" referred to a documentary style audio post production?
I need also some advice about the terms: "host dialog" and "host statement"
Thanks alot for suggestions.
AJP
We always keep on trying
Old 06-13-2005, 04:15 AM
FlorianE FlorianE is offline
Default Re: undipped meaning
'Undipped mix' for a documentary will most likely be for a foreign language release: a mix without commentary/voiceover and without any of the level adjustments done to production sound & music, to accomodate the voices. Anticipating that a foreign language overdub will have different timing, and that therefore the 'dipping' will have to be redone for each language.
Depending on your project, you might prefer to deliver this undipped mix in two stems, to allow for independent re-levelling.
Host dialog/statement I've never heard of. But it could refer to 'host language' direct sound dialog and commentary. If they want you to split this off as well, you should maybe offer to deliver on DA-88.
Cheers
Florian
Old 06-13-2005, 05:41 AM
thanks alot...
I was thinking something like this and you confirm.
They need DA-88 of course. I must deliver different stems also.
Best regards and thanks again
AJP
Old 06-13-2005, 02:27 PM
jimlongo's Avatar
jimlongo jimlongo is offline
They're probably referring to Voice over narration separate from any on-camera dialog.
Typically 1-2Mix, 3-4Music, 5-6SFX, 7Narration,8Dialog.
noise | jimlongo
Old 06-14-2005, 01:41 AM
Thanks Jim,
I've received specs from the TV network and it's exactly as you suggest!
Thanks alot
AJP
HTML code is On
The meaning of Revision differences. Philee Digidesign Hardware & Software 12 10-04-2010 03:22 PM
Undipped Mix Minus mrjk79 Post - Surround - Video 2 03-17-2009 02:39 AM
M&E's dipped or undipped? c-post Post - Surround - Video 3 12-23-2006 12:08 PM
IS there another meaning behind this sentence? Alécio Costa Pro Tools TDM Systems (Mac) 15 08-05-2003 12:40 AM
the meaning of life is in this post... badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 01-16-2003 12:04 AM
