Old 07-26-2012, 10:15 PM
tpann tpann is offline
Default Uneven mono guitar waveform?
I recorded some electric guitar onto a mono track, and the waveform is nonsymmetric. The 'bottom' of the waveform is ragged, meaning the amplitude was free to go its full extent. But the 'top' of the waveform is cut off at a specific level, so that it looks like a buzz cut.
What's causing this?
Thanks!
Old 07-26-2012, 10:47 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: Uneven mono guitar waveform?
Do you have a compressor/Limiter anywhere in the signal chain/track/bus?
Have you inadvertently 'Normalized' the track?
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Old 07-27-2012, 04:39 AM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Some distortion units give asymetric waveforms. Its just the way they work.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT 2020.......
Old 07-27-2012, 07:43 AM
I'm going through a Digitech RP250 and a Boss distortion pedal.
Either way, is this something I need to correct for?
Old 07-27-2012, 10:19 AM
WernerF WernerF is offline
What does it sound like? To quote a fellow DUC member "if it sounds good it is good". If that's the case there's really no need to worry about what it looks like.
Old 07-27-2012, 02:07 PM
bashville bashville is offline
I've seen this depending on how you play. If you're picking hard, the string can vibrate off its normal axis so it's not vibrating in equal distance swings from the relative pickup section. If you're whacking hard at some rhythm part, there may well be more energy coming "back" at the guitar pickup after the first picking swipe then in subsequent vibrations, and if it's a repeated rhythm (Ramones come to mind) the string may not get a chance to recenter itself before the next pick. So you'll see the one side, positive or negative, more than the other side until you let up and let the string vibrate on its own for a moment. It doesn't mean there's anything wrong, unless it sounds wrong. Good to observe, though.
HD Ultimate (HD Native), PT2019.12, OWC PCI-ext. TB2, Blue 192, 2018 MacBook Pro, 32 Gig, Mojave 10.14.6
Old 07-27-2012, 03:22 PM
daeron80 daeron80 is offline
That originated with Duke Ellington, actually. But I agree. Vertically asymmetric waveforms can be normal for some instruments, including trumpet and distortion guitar.
David J. Finnamore
Nyquist was right.
PT 2020.11.0 Ultimate | Omni | macOS Mojave
PT 2020.9.1 | Saffire Pro 40 | Win10
Old 07-27-2012, 06:58 PM
If you're still worried about it, try using the Audiosuite plugin called DC Offset Removal(or something to that effect) from the "Other" sub-menu. Process the clip and see if that makes any significant visual change to the wave.
Old 07-27-2012, 07:03 PM
The Weed's Avatar
The Weed The Weed is offline
And/or recalculate waveform.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 08-02-2012, 04:48 AM
Doug Ring Doug Ring is offline
Perfectly normal. Only a pure sine wave is exactly symmetrical. Your asymmetry is causing it to sound as it does, so as was already said, if it sounds good that's all that matters.
What causes waveform to be uneven necjamc General Discussion 33 05-28-2010 05:22 AM
Guitar Rig 3...mono? theaero Tips & Tricks 8 06-17-2008 08:57 PM
4 mono tracks, same input, waveform ht different el biciclista Pro Tools TDM Systems (Mac) 19 01-23-2007 01:10 PM
Can't see the waveform of a direct-in guitar signal? el biciclista Pro Tools TDM Systems (Mac) 13 06-07-2003 03:44 PM
Guitar Stereo vs. mono remote 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 07-03-2002 02:30 AM
