PT 10 HD3 TDM voice count?
I recently upgraded our studio system from PT 9 HD|3 (TDM system) to PT 10 HD software. Having 128 voices at 48k on PT 9 was severely crippling our ability to mix.
I was under the impression that with our system, the upgrade to PT 10 would give us another 64 voices, upping the total usable voices to 192 at 48k. This is not the case. Is there anything that has to be done to enable the extra voices? Because at the moment we've just paid a small fortune for what is barely an upgrade, if anything it has brought far more problems than fixes. Is there a particular setting or thing that has to be done to have the extra voices or is it automatic? Any help would be much appreciated. |
Re: PT 10 HD3 TDM voice count?
The system is 1 Core and 2 Accel cards. Is the Core card itself holding back the voice count?
Please check this document, it is the Getting Started Guide for Pro Tools 7. On page 2 it states the Audio Recording and Playback Capabilities of Pro Tools HD systems
Pro Tools HD 1 (for PCI and PCIe) Pro Tools HD 1 systems provide recording and playback of 24-bit or 16-bit audio files with the following track counts: - up to 96 tracks at 44.1 kHz or 48 kHz - up to 48 tracks at 88.2 kHz or 96 kHz - up to 12 tracks at 176.4 kHz or 192 kHz Pro Tools HD 2 Accel and HD 3 Accel (for PCI and PCIe) Pro Tools HD 2 Accel and HD 3 Accel systems provide recording and playback of 24-bit or 16-bit audio files with the following track counts: - up to 192 tracks at 44.1 kHz or 48 kHz - up to 96 tracks at 88.2 kHz or 96 kHz - up to 36 tracks at 176.4 kHz or 192 kHz So you were always capable of the track counts shown above, with PT HD 7, PT HD 8, PT HD 9 and PT HD 10. So there was no need to upgrade for higher track counts, they were there all the time. You can choose the track count in Setup > Playback Engine, you need to choose a' Number Of Voices'. It is explained on page 48 and 49 of the Getting Started Guide for Pro Tools 7 (see link above). The maximum is '192 Voices (6 DSP's)' at 44.1 kHz or 48 kHz I hope this has helped you,
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins Last edited by Delta Music Belgium; 08-18-2014 at 02:00 PM. |
Yes. HD2 Accel enables 192 voices, but you need to set it up in Playback Engine setup page. If it only shows 128 max, then you have original Process cards instead of Accel.
^ What Janne said. If your farm cards do not have a sticker on the PCI bracket that says "HD|Accel", then they are the earlier "HD process" cards. You only need one Accel card in the system to increase the voice count, and you can have a combination of Accel and process cards.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
HD native voice count | David Sandwisch | Pro Tools HDX & HD Native Systems (Mac) | 1 | 10-07-2013 10:20 PM |
HD7 voice count | Raoul23 | Pro Tools TDM Systems (Win) | 7 | 11-13-2011 01:08 AM |
PT HD voice count | garnoil | Pro Tools TDM Systems (Mac) | 10 | 11-05-2008 07:47 PM |
Trouble with Mix Plus voice count... | chucknkd | Pro Tools TDM Systems (Mac) | 10 | 03-25-2008 07:44 AM |
Voice count for PT NT|24 Mix | Euphony Sound | Pro Tools TDM Systems (Win) | 1 | 04-21-1999 10:26 AM |
