stereo to mono question
I am using a lot of VI and for what ever reason have a lot of stereo tracks where i feel i should have mono. I like the way everything sounds. If I bounce to a MONO WAV will it matter if I center the left and right pan or keep them 100% L & R? My question is will there be a difference? going MONO from Stereo but center the stereo track in the pan or leave it wide panned then go to MONO if that makes sense?
Wow am I groovy or what |
Re: stereo to mono question
If it is a stereo signal on a stereo track and you like the way it sounds then leave it stereo! If you use just one side obviously it will sound different. Personally I like some of my VIs to be mono when applicable. Minigrand and the Vacuum synth for example. There are others which are stereo only which seems a bit overkill when the output is actually mono. Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2 https://www.waves.com/r/djgsi6 |
Thanks for your input
Of course, listening is always your best friend.
If the track is truly mono; as pointed out above you won’t hear any tone difference; (although your mono gain can be affected by how you have your pan law set.) But if the patch contains some sort of stereo chorusing or other effect, when mono-summed there could be a slight warbling in sound, similar to a tremolo. I’m surprised at how few plug-ins, not to mention how few DAW channel strips, don’t have the mono button as a standard feature. There’s a couple of freebies out there, for example 4U meter from HOFA, or Panipulator from Boz, which I always keep handy to check mono compatibility. There’s another free plug, from Flux; StereoTool, which has a stereo field indicator, which you can then quickly view to see if there is any stereo information… (Sidenote; I use those tools a lot when in mixing; receiving files from outside artists, quite often in Logic and other DAWs, when they export their mono files they show up as dual mono files, which wastes a lot of system resources.)
ihatetyping |
If the sound is fully correlated (no difference between L & R), you could set the instrument track output to a mono bus and then:
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
#1 collapsing stereo tracks to mono within a stereo session so as to have the stereo VI tracks sound like mono OR # 2 bouncing a stereo session to mono format for some specific mono playback system ? If it's #1 then the simplest thing is adjust the duel pan knobs to the same number L or R in the stereo field I often do this if after the fact I decide I want a stereo VI instrument to playback more in mono. For example I might put both pan knobs for say a VI piano at 45 L or more often then not something like 40 L and 50 L (one or the great things about the way PT handles stereo track panning) is you have the option to adjust each one totally independently from the other.
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... Last edited by K Roche; 01-01-2021 at 12:12 PM. |
CPU question mono vs stereo | danyg | Pro Tools 2019 | 16 | 03-15-2024 08:40 PM |
Stereo to mono question | stixman | Tips & Tricks | 1 | 09-01-2016 01:45 PM |
A question about mono/stereo plug ins on mono tracks. | rockguitarist1255 | Pro Tools 10 | 2 | 12-24-2011 07:33 PM |
Stereo and Mono question | Daubian | Post - Surround - Video | 2 | 03-15-2007 09:08 PM |
Stereo/mono question | totemspock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-25-2005 08:28 PM |
