  #21
Old 01-14-2018, 10:00 AM
karegranat karegranat is offline
Default Re: Copy/paste plugin settings?
My preference between sends and pans would be the other way round, but I hope they all can be implemented, of course.:)
  #22
Old 01-16-2018, 03:36 AM
bucha bucha is offline
Hello Guys,
Copy / Paste send levels would be great !
  #23
Old 01-12-2019, 01:46 PM
ssi444 ssi444 is offline
Originally Posted by creativecontrol View Post
Greetings,
This is a feature request that we have heard from many previous D-Control and D-Command users who have transitioned to S6. Any suggestions about the specific implementation - switches? The ICON workflow is described in the graphic attachment.
Thanks.
https://www.dropbox.com/s/nax6laxle5...ntrol.png?dl=0
Jeff
Hi Jeff,
Is there any progress with this feature Copy / Paste Plugin Parameters?
I've just started on a new s6 stage at warner brothers and am shocked to find this hasn't been implemented yet.
Thank you,
David.
  #24
Old 01-12-2019, 10:50 PM
its2loud its2loud is offline
What is the USER button for on the Process Module? Why not make this a copy/paste button.
  #25
Old 01-14-2019, 12:50 PM
creativecontrol's Avatar
I'll defer to Eddie on this implementation. I believe there was a plan at some point for a real user customized strip using the USER button. I concur though that Copy Paste settings is indeed important and should even be expanding beyond the functionality on D-Control & D-Command.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #26
Old 01-15-2019, 06:10 AM
jmattchan jmattchan is offline
soooo not happening in this imminent update?
  #27
Old 01-16-2019, 01:53 PM
No, not yet.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #28
Old 01-24-2019, 12:44 AM
Jeezer Jeezer is offline
Good old Icon.
  #29
Old 01-25-2019, 08:15 AM
itsmemagic itsmemagic is offline
Good old keyboard.
  #30
Old 09-17-2019, 10:03 PM
Bydy Bydy is offline
Default Re: Copy/paste plugin settings? (have any of you guys written a softkey for this?)
it would be great if it was possible to have the "targeted" window be the copy source, and then remainder of the range of selected tracks respond to a "Do To Selected" command, for the parameters in that targeted insert (or send slot, but sends at least respond to "Do To Selected/All"). Boom, one softkey.
Ideally, if I had an Insert window open, with it's target square is enabled, a softkey would instigate a copy of that setting and apply it across All/Selected tracks on the same Insert slot (regardless of the plugin on that insert, which sounds like a crash waiting to be built into a softkey if you're not careful with your selections...)
It certainly is easy to do the command-shift-C/V but it can be a lot of mouse clicks, have any of you hardcore softkey people written a softkey for this to Do-To-All/Selected? I keep running into roadblocks such as targeting the same plugin on the next track as well as determining a track stopping point. Is it a third-party issue with Inserts? It doesn't seem like it when you compare it to the functionality of the Icons.
Of course as a workaround you can have custom groups for each insert with the proper allocations but that is a lot of mouse clicking and if you don't attend to each of those groups .
So easy and satisfying on an Icon, loved those switches and faders, and so useful
Thanks
C24 copy/paste settings tamtamstudio ICON & C|24 4 05-01-2016 12:19 AM
Copy settings, paste settings ? Terry Wetzel General Discussion 6 04-03-2016 06:13 AM
Copy/Paste plugin automation Rune Thuelund Post - Surround - Video 18 03-28-2012 01:35 PM
Help: copy/paste plugin parameters (ex: 2.0 to 5.1)? Floydio Tips & Tricks 2 05-26-2010 02:04 PM
copy plugin data ,paste on another parameter ? andre tchmil Tips & Tricks 2 01-17-2007 10:36 PM
