Old 12-11-2018, 11:52 PM
stefanboman stefanboman is offline
Default Locked strip=Locked send values?
I´ve noticed that often when I lock a channel to a strip, the send values get locked too.
Is this a bug or a feature/pref?
Old 12-12-2018, 05:29 AM
creativecontrol's Avatar
Default Re: Locked strip=Locked send values?
Greetings,
That behavior is certainly not intended and there are no preferences to trigger it. Please indicate the version of S6 and PT that you are currently running. I will inquire to see if it is logged.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 12-12-2018, 10:26 AM
I’m on 18.3 and 18.10 so both latest I believe.
Made a horrible video during a busy session with clients next to me.
Managed to film upside down and pointing at the wrong channels. Haha!!
But look for a channel called Hammond ST.
I have both a locked strip and an unlocked in the same shot going back and forth between the two.
https://www.dropbox.com/s/2fydp6rzue..._0432.MOV?dl=0
Thanks!
Old 12-13-2018, 02:03 PM
EddieJones's Avatar
Strange....if you move that locked track to another strip does it still do the same ?
Old 12-18-2018, 01:19 AM
Yes it moves when I move the locked strip.
So for me it seems to be easy to replicate..
Old 12-27-2018, 12:54 PM
Any thoughts on this?
Old 01-05-2019, 08:53 AM
Sorry for the radio silence. I’ll investigate this combination of versions today and report back.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-05-2019, 02:00 PM
Verified here. It doesn’t appear to be limited to Sends though however. Any possible function view on the locked track gets frozen. As a workaround, toggle the function view from the process module to any other function view (Dyn, EQ, Sends Pan...) then back to the one you want and it should un-freeze. Thanks for the data. Getting it logged and making sure it doesn’t manifest in the latest upcoming versions.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Account Locked Out dalezjc Licensing & Accounts 1 12-09-2016 02:57 PM
Why are faders locked on my 002? Keniko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-10-2006 03:03 AM
6.4.1cs2 Doesn't Locked mean Locked? EarHole Pro Tools TDM Systems (Mac) 3 12-10-2004 12:39 PM
44.1 Locked to 48 Ext. Plugs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-08-2004 08:30 PM
locked files kcir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-26-2003 10:47 PM
