Old 01-19-2021, 12:04 AM
Davidwilson Davidwilson is offline
Default D Control firmware not loading
Hi all
I have a d control that has an issue loading firmware for Main unit.
When opening peripherals and initiating the main and 2 fader packs it says firmware need updating. When i do this it stops half way and fails .
The only obvious issue is that the fader is not opperating on the focus channel.
Anyone know how to get around this issue?
Old 01-19-2021, 06:45 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: D Control firmware not loading
Originally Posted by Davidwilson View Post
Hi all
Have you tried resetting the units back to factory firmware.
power down. hold the solo, select and mute buttons on the first fader (To the left) and turn on whilst holding those buttons.
Now when you re-establish the units in the peripherals menu it should update the firmware i think. it will load the firmware to match your version of installed Pro Tools.
When you check the firmware in the utility menu does it says whats installed? Maybe it is installing and there's another reason the fader isn't working!
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-19-2021, 11:38 AM
Thanks i have tried this but wont work.
Control 24 firmware Jsalam112 ICON & C|24 7 05-21-2020 05:46 AM
Firmware on D-Control SWSPHX ICON & C|24 8 04-18-2010 04:35 PM
Freeze when Loading Machine Control Dog BBQ Pro Tools M-Powered (Win) 1 01-30-2008 01:48 PM
control the loading / or not of plugins Sdesign Pro Tools TDM Systems (Mac) 4 05-30-2005 03:17 PM
5.3.1 Pro Control firmware michael c ProControl, Control|24, Command|8 3 07-13-2002 04:33 PM
