AMD vs Intel, does it matter?
Right now the AMD quad-core 2.5ghz processors are significantly less expensive than their intel counterparts.
AMD Total (2.66ghz)- $170: processor, Motherboard. Intel Total (2.5ghz) - $260: Processor, Motherboard. Is there a downside to using the AMD processor? Does anyone know of a Socket AM3 motherboard with a compatible chip-set that has an on-board firewire slot? |
Re: AMD vs Intel, does it matter?
Athlons are considered very slow and old CPU's.
Get a Phenom-II instead. Actually, you can now get a AMD Phenom-II (3.4-Ghz) Processor for 189 dollars. Thats 1-Ghz more you can have for the same amount of money. SPEED BABY SPEED.....!! http://www.newegg.com/Product/Produc...-727-_-Product And as far as motherboards compatible and no problem boards here are 3 of the top of the line. Get the - GigaByte GA-MA790FXT-UD5P but if Newegg does not have it, then these are the next steps you should go with. 1. http://www.newegg.com/Product/Produc...-416-_-Product 2. http://www.newegg.com/Product/Produc...-427-_-Product 3. http://www.newegg.com/Product/Produc...-415-_-Product hope that helps
AMD Phenom II X4 940 w/ CoolerMaster V8 Cooler - GigaByte GA-MA790FXT-UD5P - ATI Radeon 6850x2 (x2) - Win7 x64-bit - AMS Venus-T5 with 1-TB x5 Drives Kingston Hyper-X DDR3-1066 2gig x4 (8gig Ram) - WD SATA VelociRaptor 300 (x4) - XXXXXXXXXXXXXXXXXXXX - Groove Tubes GT-66 & 55 Microphones - BBE 422-A - Aphex 104 C2 Vantec MRK250ST w/ Win7 x64-bit (HotSwaped for ProTools v8.0.4 Unit) - Acer v223w (x2) LCD Screens - Events 20/20 - Avantones - Mackie HR824 - AKG P220 - HS50m's |
All that being said, Intel is currently the hands down favorite for use with native Pro Tools, see these threads for test results..
http://duc.digidesign.com/showthread.php?t=200560 http://duc.digidesign.com/showthread.php?t=238426
You're the man Tom. This is exactly the sort of info I was looking for. Thanks.
I'm definitely going Quad-Core.
It looks like I can get a 3.5Ghz AMD chip or a 2.5Ghz Intel Chip for around the same price. Considering that Intel is the preferred chip for Protools, but that the AMD is 1GHZ faster, which do you think would be the better choice? |
Intel are going to be a better chip at this point. AMD will be cheaper (and possibly a better price/performance). But, it's not all just more Ghz the better, check out the CPU charts here and compare. See which one has the best spec for the amount of money you want to pay. AMD MB's are usually a bit cheaper than Intel ones, and they seem to be upgradable for future CPU's better than an Intel platform.
http://www.tomshardware.com/charts/2...hmarks,60.html All that said, if I were buying a new computer it would likely be an Intel at this point... Joel |
So here's an AMD build and an Intel build, any opinions?
Intel ($403): Processor: Intel Core 2 Quad Q8300 Yorkfield 2.5GHz Motherboard: ASUS P5Q Pro Turbo Memory: CORSAIR 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 AMD ($419): Processor: AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Motherboard: GIGABYTE GA-790XT-USB3 Memory: CORSAIR 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 |
Yes. More RAM. :)
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Cool. I'm leaving slots open in the future so I can upgrade. But between the AMD and Intel, any suggestions or reasons why one is the better choice?
Leaving room for expansion is good but you might want to go with 2 x 2GB sticks so you can expand to 8 down the road. Newegg is listing some P45 boards as open box as low as 66.00. I've had pretty good luck with open box products from them. Unless you are planning on four monitors you may not need the Pro version of the board. Long time DUC'er MATTP has been running ASUS P5Q SE2 and a Q9450 that I traded him for some time now. The P5Q SE2 and the P5Q SE Plus seem to pretty be the same board.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
the box doesn't matter? | mcconnellsteve | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-25-2006 06:01 PM |
Clipping no matter what | amorena1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-19-2005 10:41 PM |
Won't record PT 4.0.1, what's the matter? | cranialcompany | Digidesign Hardware & Software | 2 | 11-19-2005 07:54 PM |
DOES IT MATTER? | jon one | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-13-2003 08:26 PM |
From OS 9 to 9.2 does it really matter? | Craig Golding | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 12-13-2002 05:42 AM |
