Old 02-05-2018, 07:26 AM
priorytools priorytools is offline
Default Constantly Changing Random EQ & Saturation ?
Hi Folks. .
I'm looking to try something on an old Linn drum part.
I'd like to make it constantly variate, change slightly, with some subtle eq & also maybe saturation. . .
Does any one know of any plugins that achieve this ?
I have a side chaining plan, but thought I'd just put this out there in case there is something that has a "random" setting to save time . .
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 02-19-2018, 04:04 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default Re: Constantly Changing Random EQ & Saturation ?
Originally Posted by priorytools View Post
Hi Folks. .
Don't know about random, but you can use automation for that.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 02-19-2018, 04:07 PM
amagras amagras is offline
Yes, with automation is easy, here's the basic concept explained with volume but you can do it with any parameter that can be used be automated
https://youtu.be/qa_dScTrYoM
Here are the steps I follow
https://youtu.be/Cyfuu3GHTTo
Another thing you can do is try modulation, the WOW control of J37 in a slow setting can do wonders with drum machines.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 02-19-2018, 11:31 PM
Cool. Thanks people, I’ll check them out.
Old 02-20-2018, 05:55 AM
simon.a.billington simon.a.billington is offline
You could try a Fuzz-wah type of effect and blend in only a tiny bit of it.
There may even be one out there that does a random thing instead of modulation or manual control.
Actually, have a look at Metafilter by waves, it could possibly give you what you want, plus a mix knob to blend in the results.
https://www.waves.com/plugins/metafilter#image
Old 02-20-2018, 06:44 AM
Great idea! the new Tube Modulizer by Audiority allows you to choose the type of waveform you want and it has a strong character that sounds great on percussion
https://youtu.be/YiFBZlUPfAU
Here's you can hear the character of the different models without the modulation
https://youtu.be/7nfDyVtiTGQ
amagrasmusic.com
For anyone who is having the random white noise burst / random distortion problem Philly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-23-2010 04:56 AM
random crashes when opening or changing plugins swethington 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-21-2008 05:15 AM
Random changing of the pitch of tracks dcf16 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-20-2005 09:56 PM
-9073 and -6086 DAE Errors RANDOM, RANDOM, RANDOM mikerica101996 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-13-2004 01:08 PM
OFFICIAL!! Random mute bug not random!! Gwyn ap Harri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 10-09-2003 10:27 PM
