  #61
Old 05-11-2012, 05:11 PM
Seth Thomas Seth Thomas is offline
Default Re: Digi MIDI i/o Duplicated and greyed in Audio/Midi setup
There is a new MBoxPro3 Driver…. v10.21. Perhaps this will resolve out little Ghost problem, yes?
Best,
Seth
  #62
Old 05-11-2012, 05:16 PM
Dang! Sorry, the Driver is still .14. The .21 is for the MBox, not MBoxPro…
  #63
Old 05-11-2012, 05:30 PM
bradp bradp is offline
rats!!!
have you tried removing the gr55 driver or others in the same folder as the mbox driver?
check both root and home library folder
thanks, brad
Mac Pro:
PT 11.3.2 HD native, MIDI IO, 96IO
Mac Pro Desktop 4,1 osx 10.11.6., 8 Core 2.26GHz 2009 Intel Xeon MB535LL/A 16GB RAM 640GB HD ATI 4870
MBP:
OS 10.11.6, MacBookPro 5,1, Intel Core 2 Duo 2.4GHz Memory: 8 GB Bus Speed:1.07 GHz, Boot ROM Version: MBP51.007E.B06, SMC Version (system):1.33f8
  #64
Old 04-27-2013, 03:45 PM
@ndy's Avatar
@ndy @ndy is offline
I have ditched my old Harpertown Mac Pro 3.1 and switched to a New Mac Mini. The Midi I/O is running flawlessly now. I understand now why Avid is leaving that model off the "supported" compatibility charts.
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4
  #65
Old 08-02-2013, 07:18 AM
joeman joeman is offline
Hi @ndy and everyone else,
I have a slightly different issue and I'm wondering if anybody could help me.
I'm using a MacBookPro (mid 2012) running Mountain Lion 10.8.2.
I recently purchased a DigiDesign MIDI I/O second hand.
I do not own a copy of Pro Tools. I have managed to find the latest drivers and software for the MIDI I/O but the problem I have is that it appears I also need the Firmware Updater Application to update the firmware on the MIDI I/O.
Apparently this Firmware Updater Application comes bundled with Pro Tools install?? Unfortunately, I can't find it anywhere to download from the website.
Would anyone be able to please help me either find the firmware updater app or email me a copy of it?
At the moment, the drivers install fine on the computer but the MIDI I/O does not appear in AMS list at all.
@ndy, you say you're using the MIDI I/O on OSX Lion? I also have an iMac that is running Lion (10.7.5). If I can get the MIDI I/O running on either machine it would be great.
Thanks for your help/time
Joe
  #66
Old 08-02-2013, 08:10 AM
Hi this is Joe again,
I found the firmware updater app.
It turns out it was automatically deposited into a Pro Tools folder in the applications folder without my knowing. I searched the internet for 2 hours looking for a solution to this issue so I'm a bit annoyed that this was not documented.
Anyway, I'm happy that it is now all working properly, at least for now. (on Mountain Lion 10.8.2)
Cheers all!
Joe
  #67
Old 08-02-2013, 08:42 AM
Cheers all!
Joe
hi joeman!
would you let me know if you ever get a midi IO ghost icon in the audio/midi setup app?
thanks!
thanks, brad
Mac Pro:
MBP:
  #68
Old 08-02-2013, 09:01 AM
Hi Brad,
If you go here:
http://avid.force.com/pkb/articles/e...nload/en379411
Then find Additional downloads, and then download the driver for mac or windows.
Install it. Then in your applications folder (if on mac) there'll be a folder called Digidesign/Pro Tools/MIDI IO/ and here you will find the firmware updating app.
I hope this helps!
I will let you know if I have any further issues re greyed out device or similar.
Joe
  #69
Old 08-02-2013, 07:52 PM
@ndy's Avatar
Hey Joe, glad you got it sorted. I'm running 10.8.4 and the Midi i/o is running perfectly. Brad, no greyed out duplicates. The problems with USB communication loss was limited to my Mac Pro 3.1, so it was Apple's fault all along. That model Mac Pro had all kinds of problems, especially heat issues.
  #70
Old 08-02-2013, 08:40 PM
anyone running a Nehalem 4,1 mac pro? thats the one i have the midi IO issue with. the previous G5 i had also had the issue.
thanks, brad
Mac Pro:
MBP:
Audio MIDI setup says DIGI 002 midi device is offline oliarnalds MIDI 17 10-23-2016 10:13 PM
Remove a Greyed-Out Device in Midi Setup? Reesho 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-14-2016 12:58 PM
Midi IO not shown in AMS or is greyed out. When greyed out no MIDI options in Tools drewsmith Pro Tools TDM Systems (Mac) 3 10-15-2011 06:21 PM
Midi Regions / Losing the first midi note when duplicated sad1robot Pro Tools TDM Systems (Mac) 8 02-10-2010 05:40 PM
Can't see the Digi in the Audio/Midi setup jpoprock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-01-2003 08:27 PM
