Old 01-07-2019, 07:50 AM
Armando Armando is offline
Default TC Level Pilot use with Control 24??
Hello!
I’m considering trying a TC Electronic Level Pilot Monitor pot as my monitor output level controller. I’ve never liked the “stepped” feel of the Control 24’s Monitor pot.
If I place the Level Pilot in between the Control 24 and active monitors and set the Control 24’s Monitor pot to “full”, will there be any adverse affect to the overall sound once it’s being controlled via the Level Pilot?
Thanks!!
Armando
Old 01-07-2019, 08:21 AM
Southsidemusic's Avatar
Default Re: TC Level Pilot use with Control 24??
Nope! Works fine
PS. You don’t need to put the monitor volume to full as that might distort the overall output of ghe sound. We always let the volume on our Barefoot MM27 and our 5.1 Genelec system stay at half as that sounds enough.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 01-07-2019, 08:35 AM
Originally Posted by Southsidemusic View Post
Nope! Works fine
Thanks for replying!
Question on your reply; I believe you’re saying that you only have your active monitor’s output set to half. I’d like to know if it’s ok to set the Control 24’s Control Room Monitor output to “full” if I’m using the TC Level Pilot as the actual Control Room Monitor Level Controller.
Armando
Old 01-07-2019, 08:40 AM
I would not do that as the monitor section on the Control 24 is not that good and thats been said a lot. I would rather have maybe 60-70% on the control24 and if you feel you need more output then start the monitors at 50% and add volume there instead all IMHO of course
Best Regards
Christopher
#thestruggleisreal
WEBHOME
DSP Pilot App hanging qtvaudio System 5 6 04-25-2017 07:44 AM
TC Level Pilot w/Control 24?? Armando ProControl, Control|24, Command|8 2 06-29-2015 10:04 AM
FS: Black Lion Audio White Sparrow D/A with TC Electronic Level Pilot $1600 whittybeats Buy & Sell 3 10-21-2014 03:20 PM
FS: TC Electronic Level Pilot crandallwarren Buy & Sell 1 06-30-2014 06:10 PM
AES Level Control ? soundonsound Pro Tools TDM Systems (Mac) 13 07-06-2008 09:00 AM
