Old 01-08-2004, 04:01 AM
dfusion dfusion is offline
Default Will PC2700 memory work in PC2100 memory slot?
I wanted to move some RAM from a motherboard using PC2700 to a system that uses PC2100. In the old days I remember PC133 was backwards compatible with PC100 and I wasn't sure if the same is true for PC2700?
Thanks!
-d
Old 01-08-2004, 06:16 AM
ikke ikke is offline
Default Re: Will PC2700 memory work in PC2100 memory slot?
That should work.
Allthought for best performance u should use the same memory sticks. If the first is pc2100, the second and third should be pc2100 as well. According to the instruction manual from my ASUS MB..
Old 01-08-2004, 09:30 AM
Thanks ikke! Yeah I'm going to be replacing two 128MB with two 512MB, so they will be identical sticks!
Kontakt Memory Server (KMS) Could not start MemoryServer. Memory Extension will be... John_Toolbox Virtual Instruments 5 12-29-2011 10:03 AM
MEMORY ERROR MESSAGES- Strange memory loss hwill2008 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-23-2010 08:14 AM
Samsung PC2700 Memory martinmbenz Tips & Tricks 5 12-09-2002 03:55 AM
Question on PC2100 Memory flashbak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-24-2002 08:49 AM
Promting lack of memory on PC with adequate memory! Any tips? will22 Digidesign Hardware & Software 12 09-20-2001 08:36 AM
