Promting lack of memory on PC with adequate memory! Any tips?
My system is a PC P3 667MHz, with 384M RAM, however after loading the software and completing any application, PT prompts error6008, basically a lack of memory. If anyone could offer any advice, it would be much appreciated! [img]images/icons/smile.gif[/img]
Re: Promting lack of memory on PC with adequate memory! Any tips?
I had that problem once when I had to re-format my hardrive and re-install PTF, it turned out the swap file wasn't big enough. Used Norton utilities to defrag and optimize my swap file and the problem went away.
Ill give it a shot. Thanks for that. [img]images/icons/smile.gif[/img]
Unfortunately, that didnt fix the problem. Anything else that anyone could recommend would be appreciated.
Check your system.ini vcache settings and Windows' virtual memory settings.
www.tascam.com gives great info on how to tailor these to your specific needs, not just 'plug in 25400' like so many of these generic computer optimization guides. There are at least 5 other sites with similar pro audio info at evilchopper.com/linkses.htm Clear out all programs running in the background, especially anti-virus, that may be using memory. Also check if all your ram chips have same bus speed. Good luck Chopper |
Thanks for that. Ive done everything on the tascam hdd optimisation list, without any joy. However, I dont know how to check my rams bus speed. Could you/anyone enlighten me?
just look at the sticks of ram inside, if your computer was recently purchased new, it's probably not an issue, but I've had a few ram sticks turn out to be pc100s when they were labeled pc133s. The slow and inconsistent performance was confusing at first, till I noticed the stickers 'pc100'and then peeled them up.
Now that I've got pc133's the PIII800 runs like a champ. good luck Chopper |
Thanks evilchopper. I checked the ram, and yes one was 100Mhz and the other 133Mhz. I removed the 100, leaving 256M installed. Alas, no joy again! [img]images/icons/frown.gif[/img] Im thinking something/someone just doesnt want me to run PT! My last thought is to check the performance of my ram to make sure its working properly. If anyone knows of any software which does this (or any other way)I would appreciate it.
Maybe this will help you:
DocMemory or DIMM ID 2001,at http://www.vml.co.uk/Frameset/Frameset%20master.htm
bnt |
Still no luck! Thanks to everyone for their help, but it looks like ill have to buy the oppisition software!
Kontakt Memory Server (KMS) Could not start MemoryServer. Memory Extension will be... | John_Toolbox | Virtual Instruments | 5 | 12-29-2011 10:03 AM |
MEMORY ERROR MESSAGES- Strange memory loss | hwill2008 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-23-2010 08:14 AM |
Memory is Low? Quit and Allocate more memory to PT | Unite | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-08-2004 05:38 PM |
Will PC2700 memory work in PC2100 memory slot? | dfusion | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-08-2004 09:30 AM |
More memory or faster memory | trostals | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-12-2002 02:49 PM |
