Old 03-19-2024, 05:20 PM
Danbvz64 Danbvz64 is offline
Default Tracks Contain Plugins That Don't Exist In Your Plugin Folder
For the past few months I've been getting the following message when opening up an existing session in Pro Tools First: "One or more tracks contain plug-ins that don't exist in your plug-in folder." At first I would get this message only occasionally, and when I did, I would simply close the session, exit out of Pro Tools First and then open it all back up again and my plug-ins would all be there in my session, as they should be. But for the past few days, every time I open up a session, I get this message. And no matter how many times I close and re-open PTF, I keep getting the same message. I've also tried rebooting my PC. The attached screenshot shows the message that I get. In this instance it's the Eleven MK II plug-in that can't be located. But when I go into the "C:\Program Files\Common Files\Avid\Audio\Plugins" folder, the Eleven Mk II is there (see attached screen shot) along with all of my other plug-ins. If I open a session and click on an empty Insert, what I've found is that all of the plug-ins that automatically came with PTF are there. But almost all of the plug-ins that are included in the Avid Complete Plug-in Bundle (which I have a paid subscription for, and have been using for the past 2 years) are missing. Has anyone else experienced this, or have any suggestions as to what's causing this and how to fix it?
Pro Tools First 2020.9.0
Focusrite Scarlett 2i2 audio interface
Dell Inspiron Intel i5 core processor (2.70 GHz)
8 GB RAM 1 TB Hard drive
Windows 10 (64 bit)
Old 03-20-2024, 04:56 AM
tope d's Avatar
tope d tope d is offline
Default Re: Tracks Contain Plugins That Don't Exist In Your Plugin Folder
Hi there!
Let me check on this and get back to you in a bit
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 03-20-2024, 05:09 AM
tope d's Avatar
Based on your screenshot, the ElevenMKII plugin is still inside your plugins folder. You can move this to a different folder and launch Pro Tools then see if the same issue occurs.
Thank you
File Type: jpg Screenshot 2024-03-20 at 8.06.57 PM.jpg (54.2 KB, 0 views)
-Tope
www.topedomingo.com
Old 03-20-2024, 05:11 AM
tope d's Avatar
To give more info on this. The ElevenMKII plugin is not included with Pro Tools First. Also, Pro Tools First has been discontinued. There is a new free version which you can check out on this LINK.
-Tope
www.topedomingo.com
Old 03-22-2024, 01:39 AM
Kaneepa Kaneepa is offline
That's what's happening to me since installing 2024.3 on my Mac Studio Ultra, I have a thread open on Pro Tools forum here at the DUC.
Old 03-23-2024, 01:05 PM
Anyone ?
HTML code is On
moved unwanted plugin to UNUSED plugins folder - then it reappears on PT launch strawb Pro Tools 4 04-16-2022 10:54 AM
Pro Tools requires the DSP mixer plugin in the plugins folder!!!!!! crizdee Pro Tools 10 13 10-23-2021 07:48 AM
copy AAX plugins to new rig’s Avid plugin folder? MixerGuy Pro Tools 2020 3 04-01-2021 06:59 PM
Protools first not identifying purchased plugin even though it's in my plugins folder Hibbledthatbibble AAX Plug-ins 1 09-15-2020 12:39 PM
UAD TDM PLUGINS NOT FOUND IN PLUGIN FOLDER heromusic Pro Tools TDM Systems (Mac) 1 03-13-2008 02:24 AM
