Old 03-10-2024, 12:24 PM
BGMusic BGMusic is offline
Default Antares plugins (mostly) do not show up in PT 2024.3
PT 2024.3 Studio / Mac M1 Pro / UAUDIO Twin Thunderbolt / Antares latest plugins
The only plugins that show up are Auto Tune Hybrid, EFX, EFX +, Vocal Reverb and my old version of AT 7. THis happens in native and in Rosetta. All of the Antares plugins show up in Logic Pro X and Ableton Live on the SAME MACHINE!!! I've tried to contact Ableton support but you know the answer to that one. Is this a problem with PT, Avid or Antares as it is FRUSTRATING? I also tried trashing PT preferences. So please, someone, what goes on here.
Old 03-10-2024, 01:15 PM
Default Re: Antares plugins (mostly) do not show up in PT 2024.3
Do you see errors when 2024.3 is loading plugins? If so (or just anyhow try) trash the plugin cache (or trash all prefs) and try again. Plugin load issues are widely being reported on DUC. You say you tried trashing prefs but make sure you really got the plugin cache file... use Pete Gates PT Prefs 2 utility to be sure (edit: nope do it by hand, see below).
And by not show up you mean under the insert menus in Pro Tools?
Are the .aaxplugin bundles for these missing plugins actually in the plugin folder?
Do you see those missing plugins load at startup? If not sure trash the plugin cache file again and watch, Pro Tools will load them slower as it rebuilds the cache and you should see them load.
Look in the Pro Tools Log file ~/Library/Logs/Avid/Pro_Tools* and see where it is loading plugins and what it does with these missign plugins... a good way to use these log files is to compare line by line an old log file that worked OK and these where something is going wrong.
You are migrating from what exact setup? Where it worked OK? It's next to impossible to work out what systems you have from any of these long descriptions. You really ought to clean up your signature and use proper Apple model names and try to present this in a way that is less painful to try to unpick.
Old 03-10-2024, 01:33 PM
And a reminder the plugin caching changed in 2023.12 and later:
Mac: /Users/Shared/Pro Tools/AAXPlugInCache/*
Windows: C:\Users\Public\Pro Tools\AAXPlugInCache\*
Remember to quote or escape the space in "Pro Tools" if doing this from the command line.
And I just realized from the build date that that the current version of PT Prefs 2 probably does not smack these plugins cache files correctly.
Old 04-14-2024, 09:38 PM
Mike Pfeifer Mike Pfeifer is offline
I'm having the same problem with Spitfire plugins - I have tried trashing everything I can find with no luck. I have tried repairing the plugins, and trashed prefs including the new plugin cache. Unable to get Spitfire plugins to show up in Pro Tools at all.
Last edited by Mike Pfeifer; 04-14-2024 at 09:39 PM. Reason: Edit to add that pro tools version is 2024.3.1
Old 04-14-2024, 10:32 PM
These were all working before? On what exact version of Pro Tools and what exact macOS. Of all the things suggested in this thread what have you tried doing?
What exactly have you done since stuff last worked?
Are you sure all the installed plugins are Apple silicon native... run a PT Prefs 2 plugin report and check they are all universal?
Old 04-23-2024, 12:19 PM
Ghost In The Attic's Avatar
Ghost In The Attic Ghost In The Attic is offline
Do you have Kontakt?
I am still on an Intel Mac and can't see Spitfire plugins in the PT menu either. But, if I open Kontakt, I can see and load Spitfire plugins in that.
Edit: I am running Pro Tools Ultimate HDX on Monterey 12.7.4
Retro 176 (pair), Pultec EQP-1A (pair), Germanium Comps (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL Fusion, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM92, PCM70... Amps, Amps & More Amps.
HTML code is On
Missing AAX Plugins.. 2024.3 problem. Kaneepa Pro Tools 8 03-27-2024 04:33 PM
[FS] $350 [104 Waves Plugins] SSL CLA API Puig Tape DIAMOND Vinyl OMNI Abbey WUP 2024 Electronic1982 Buy & Sell 2 12-05-2023 02:35 PM
[FS] $299 [28 Waves Plugins] SSL CLA API Puig Tape Vinyl OMNI Abbey Kramer WUP 2024 Electronic1982 Buy & Sell 0 11-26-2023 01:58 PM
Pro Tools/D-Show standalone integration idea with D-Show show files/virt. soundcheck digidesigner VENUE Live Sound Systems 2 11-08-2011 02:52 PM
Does anyone use antares avox 2 plugins? BGMusic Pro Tools TDM Systems (Mac) 0 01-12-2010 07:28 PM
