Old 03-04-2024, 08:36 AM
willmo04 willmo04 is offline
Default Speed of Imported Audio Slowed
Hello all.
Im currently trying to do a drum cover of a song with my electronic drum kit.
I found a drumless track online and downloaded it.
Did file>import>audio
Selected the file.
Opened the options to convert it.
Made sure SRC was selected to convert from 41kHz to 48kHz (current session SR)
I also matched my session bit depth to the imported audio's bit depth (but also tried it without doing that).
The audio doesn't line up with the midi drums I recorded.
It slows down over time.
I do not have any tempo changes in the session.
The midi has lined up fine with some other files.
Sometimes it works, sometimes it doesn't.
Any thoughts are appreciated!
Old 03-04-2024, 12:06 PM
Top Jimmy's Avatar
Default Re: Speed of Imported Audio Slowed
It sounds to me like the tempo of the audio file isn’t the exact same tempo as your session. Do you know how to change the tempo of the session to match the audio?
James Cadwallader
Old 03-04-2024, 12:40 PM
^^^ What Jimmy says. And maybe there are tempo changes in that audio you downloaded.
In general you cannot rely on two things that are presumably the same tempo/beat to just line up. Not unless they are MIDI/VI tracks with proper clocking as needed. Thankfully lots of music is not such a robotic thing.
You can try fine tuning the tempo of your stuff, or move your MIDI around manually if needed or maybe use elastic audio on the audio tracks you have downloaded (please less robot, try the earlier options).
Old 03-04-2024, 12:47 PM
I do! Also, I tried creating another session with the sample rate to match the file and it did the same thing. I imported the original of that song (not the drumless track) and it worked just fine. It may just be something with that file specifically.
Old 03-04-2024, 01:06 PM
Then you can compare the drumless and original tracks side by side in Pro Tools and see what the difference is.
The most common mistake out there is files just reporting they are one sample rate when they are the other. The common thing then would be 44.1 vs 48 and you would hear the pitch shift, or maybe somebody goofed and also pitch corrected the file, or if the tempo really varies then somebody elastic audio'ed or vari-speed rerecorded that track. These sorts of problems are effectively always input file sample rate type issues not due to the DAW.
Old 03-04-2024, 01:37 PM
That’s a very good point. I’ll give that a shot when I get the chance. Thank you very much!
Audio import playback is slowed twistedinsane macOS 5 05-19-2019 07:45 AM
Bizarre behavior- imported audio plays at 1/2 speed Nilreb Pro Tools 11 4 01-30-2016 05:14 PM
My tempo is slowed down after audio import dudaman Pro Tools 11 3 01-15-2015 09:42 PM
Imported OMF - wrong speed and pitch lanstrad macOS 1 05-05-2012 10:12 PM
Audio seems to have slowed down? proverb18 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-22-2005 09:37 PM
