Old 02-16-2024, 01:20 PM
Bender Bender is offline
Default Audio File Store
I'm back after a long break
I'm using Pro Tools Artist on my Mac
I start a new session and I import some audio files I have from a Hard Drive I saved
After I save the session and disconnect the HD the files don't show up in the session anymore. In the previous versions of PT it would save any imported audio in the session folder.
What am I doing wrong?
Thanks
Old 02-16-2024, 01:35 PM
Default Re: Audio File Store
You need to tell Pro Tools to copy audio content when you import it so it copies the file into your session folder. You can set it to always do this, and that is a good idea.
If you have sessions with stuff in unknown places do a save copy in to put the media in the session folder. You need to understand the difference between Save As and Save Copy In.
All this is discussed in the Pro Tools reference guide.
If you have old sessions on external drives you should be trying to work as safely as possible. Mount that drive read only, copy sessions from there to your fast internal SSD. Return the external drive to its save hiding place when not in use. Hopefully there are multiple backups already of these drives.
Old 02-16-2024, 01:36 PM
sw rec sw rec is offline
(A) Do you have “copy files on import” checked in your preferences?
(B) Even if you did do (A) I’ve found it’s still best to drag the files into the main session folder anyway. “Copy on import” hasn’t worked reliably for me.
Old 02-16-2024, 01:50 PM
I did have copy on import checked but it did not work.
I dragged them as suggested and used Save copy instead of save as and it worked
Thanks, guys
Universal Audio Store Not Working Z-Chord AAX Plug-ins 2 12-31-2015 03:43 PM
Is there a way to store Tempo with audio in PT 11 necjamc Pro Tools 11 8 02-03-2015 12:22 PM
Please point to to where I can re-download my PTLE7 setup file? Store won't help. mfleming 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-26-2009 08:05 PM
M-Powered 8 upgrade is in the M-AUDIO store Richard901 Pro Tools M-Powered (Mac) 2 12-17-2008 09:17 AM
How do I store audio on my external hardrive? surfersafari 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-02-2007 11:16 PM
