Old 11-27-2023, 07:20 AM
Armando Armando is offline
Default How to get PT HD10 to recognize Digi Pre
Hello! For whatever reason when starting my PT HD 10.3.10 rig the attached Pre isn’t connected. I can usually control it either via GUI or Control 24. It’s connected to a Digi Midi I/O if this helps. I went into setup(Hardware and I/O). Pre is shown but where you select midi in and out it just shows Pre1 in italics.
Anyone remember the fix? Thanks!!
Armando
Old 11-27-2023, 09:10 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: How to get PT HD10 to recognize Digi Pre
DigiDesign MIDI I/O should work with PT10, but please try another USB/MIDI interface. Anything that says DigiDesign is not promised to work past DigiDesign PT 8.1.1
Janne
Old 11-28-2023, 04:22 AM
Update: the problem wound up being a powered USB extender I’ve used for years. The power adapter was causing the issue so after receiving a new replacement everything is working fine again!
Armando
HTML code is On
Midi won't recognize my Digi 002 wfenlon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-21-2013 07:55 PM
PT10 does not recognize Digi 003? dmarionmusic macOS 5 03-07-2012 09:00 AM
PT9 won't recognize Digi 002 Rack btovsky Pro Tools 9 32 12-10-2011 08:15 PM
PT9 Digi 002 recognize problem kidboy500 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-06-2011 11:03 AM
does powermix 4.3.1/4.3.2 recognize digi I/Os? love666 Pro Tools TDM Systems (Mac) 1 04-04-2001 03:47 AM
