Old 09-13-2023, 05:35 AM
browser browser is offline
Default HD Driver not load on Monterey external drive
Hi , i have a mac studio with monterey, avid chassis with one HDX card, protools 2023.3.
I've installed an external monterey system where I can't load the HD Driver.
Everything works fine with the internal system drive.
I've followed all the Avid (Best practices for installing and troubleshooting the Avid HD Driver on macOS)
When I try to manually open driver with the avid utility, I have this window:
Password:Executing: /usr/bin/kmutil load -p /Library/Extensions/DigiDal.kext
Error Domain=KMErrorDomain Code=71 "Could not find: Unable to get contents of boot kernel collection collection at /System/Volumes/Preboot/B85E0797-2C0A-4572-8334-245BFE125EAF/boot/8DF3E10614960D82AED00FC59CE5A4CE18C192EADD9C451AF7 D6784A81B27B0850AAE3213B9C51AA2FB8BBA5F6D7EA31/System/Library/Caches/com.apple.kernelcaches/kernelcache" UserInfo={NSLocalizedDescription=Could not find: Unable to get contents of boot kernel collection collection at /System/Volumes/Preboot/B85E0797-2C0A-4572-8334-245BFE125EAF/boot/8DF3E10614960D82AED00FC59CE5A4CE18C192EADD9C451AF7 D6784A81B27B0850AAE3213B9C51AA2FB8BBA5F6D7EA31/System/Library/Caches/com.apple.kernelcaches/kernelcache}
The only thing that might be a problem is that I can’t validate the driver authorisation on install because it never shows it, even if I stay with the security pref open.
I can see the HDX card in PCIE and the DIGIDAL extension in the system.
All this is for every new Monterey I have installed on 2 different external SSD drives.
Any ideas ?
Thanks for reading.
Old 09-13-2023, 08:11 AM
tope d's Avatar
tope d tope d is offline
Default Re: HD Driver not load on Monterey external drive
Any ideas ?
Thanks for reading.
Sorry I can't find any Avid Account linked with your registere Email on the duc. Can you update your Profile so I can start up a support case for you on this?
Thank you,
-Tope
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 09-13-2023, 10:43 AM
Originally Posted by tope d View Post
Thank you,
-Tope
Thank you, i've changed the email.
Old 09-13-2023, 10:53 AM
Jeez just wrote a para about trying with the prefs panel open... oops, glad I reread your post before posting. So good you know about the driver privilege alert popup not appearing.
Maybe it's possible here if you insitu upgraded your boot drive macOS you got the third party driver permission grandfathered. But why it's not letting you grant this for a third party driver on the external disk is not good.... and you've obvious disabled SIP etc. for it to work at all.
But I suspect the bug is real and known by Apple. See https://developer.apple.com/forums/t...ge=1#744733022 I was aware of this through the Fuse software community. Developers there have been having problems when booting from external drives and trying to load their Fuse drivers. Maybe Avid support is all on top of this with Apple, I have no idea.
Old 09-14-2023, 12:56 AM
Thank you for your reply, yes i've downgraded sip and the lower level don't do anything more.
Old 09-14-2023, 01:50 PM
Please do get in touch with Avid support, and see if they know what Apple is doing for a fix here. And if they don’t know about this please make sure they see the link I gave.
Old 09-18-2023, 01:03 AM
I will see with avid but i don't have time for this now. I will give the link.
But sure they know about that.
Old 02-10-2024, 07:46 AM
Analogue Analogue is offline
Hi! Just upgraded to M1 Studio Ultra, Ventura 13.6 and I have the same problem. Can't install the ProTools HD driver on an external system SSD.
Works on the internal drive. Although the install procedure wasn't exactly straightforward....:-
I created a case in AVID support, they're on it, but just wanted to check if any of you found a solution so far?
Many Thanks
Old 02-22-2024, 06:36 AM
prfraczek prfraczek is offline
try from terminal: echo -e 'YOURPASSWORD ' | sudo -S touch /Library/Extensions
Old 02-22-2024, 11:03 AM
I have no idea if that will help or not but please don't do this echo password stuff. This is bad infosec behavior and could result in your plain text password being stored in numerous log and history files etc. Use sudo conventionally and let it ask you for a password.
Want to dual boot Mojave and Big Sur or Monterey...same drive or separate drives? RobbaDobba macOS 4 10-25-2022 11:56 AM
PT 2022.5 M1Max macOS 12.4 Monterey Won't Load Just Phab Pro Tools 14 06-30-2022 02:05 AM
Plug-Ins won't load on Monterey DHS AAX Plug-ins 30 03-28-2022 11:25 PM
OMS driver can't load Artie Digidesign Hardware & Software 1 03-23-2004 08:34 PM
PT will not load driver for 002 Please Help !! MSY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-17-2004 03:40 PM
