Old 03-02-2023, 04:53 AM
aneirin_w aneirin_w is offline
Default Avid's Pro Subharmonic Not Nulling
Hi all,
Does anyone knows what settings in Pro Subharmonic causes it not to null?
I've got a track that i recorded twice with the same settings, flipped the polarity on one of the track and it does not null!
Thanks in advance.
Old 03-02-2023, 05:09 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Avid's Pro Subharmonic Not Nulling
Hi, welcome to the community.
Unless you recorded a perfectly stable sine wave, any kind of modulation before the plugin causes it to not null.
Janne
Old 03-02-2023, 06:19 AM
Farhoof's Avatar
Farhoof Farhoof is offline
What version, OS, PT version, dsp or not, etc?
Subharmonic has been bugged for a while generating different outputs each time you press play. I'm not sure it's fixed. Does it sound the same but just doesn't null or is there a (huge) level difference?
See also: https://duc.avid.com/showthread.php?t=399381
Old 03-02-2023, 07:08 AM
Yeah, I've been bitten by this before. If I use it, I generally use it for something specific, and print it right away.
Scott Gatteño
Old 03-03-2023, 02:53 PM
That is interesting, I've just tried it with sine wave track and it does indeed null. Does not work well on any instrument - tried on drums/bass/keys
Old 03-03-2023, 03:00 PM
That's a great thread! thanks.
Just A/B-ing them, I can't really tell much of a level difference, but when I invert the polarity of one of them, there seems to be some phase cancellation.
I'm using PT 2022.12, same as the plugin. Using Monterey V12.6.3. Plugins are running natively.
Old 03-03-2023, 03:03 PM
Does seem like that will be the approach I'll be taking now! haha
Old 03-03-2023, 03:30 PM
JFreak's Avatar
Modulation (f.ex reverb) by definition does not null if you compare two different prints.
Janne
Old 03-03-2023, 04:25 PM
Eric Lambert's Avatar
Yeah, I don't know that anything is broken, it's just the nature of chaotic processing where each time there's a different result, perhaps undetectable by the ears. I wouldn't worry about it, unless you're doing something that requires bit-accurate repetition.
Old 03-03-2023, 10:57 PM
smurfyou smurfyou is offline
I really like the sound of it but ever since the output level bug ^^ I tend to just print it as I go.
~Will
HTML code is On
FS:Avid Pro Multiband Dynamics & Subharmonic mgoorevich Buy & Sell 2 05-07-2018 01:02 PM
Avid Pro Subharmonic Mark Dann Buy & Sell 4 12-01-2017 11:15 AM
Avid Pro Subharmonic Mark Dann Buy & Sell 4 03-10-2017 01:01 AM
Avid Pro Multiband Dynamics & Pro Subharmonic DHL AAX Plug-ins 25 11-24-2014 07:06 AM
