Old 03-07-2022, 11:56 PM
the-flava the-flava is offline
Default Does 003 driver Work on Windows 11?
Till now my Digi 003c works great on my Windows 10 PT 2021.21. but Im thinking about to Upgrade my PC for more power (i9 12900k). I gona stay on Windows 10 for Now. But if i have to upgrade one day to Windows 11, do i have to buy a new soundcard?
Old 03-08-2022, 05:16 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Does 003 driver Work on Windows 11?
I have an old 002 kicking around that I had briefly working on Win 11 (same drivers as the 003). Should work, but not officially supported.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 03-08-2022, 10:33 AM
Joel
Thanks for responsing!
Old 03-08-2022, 12:18 PM
EGS's Avatar
EGS EGS is offline
I'd jump right to 11 for a new i9-12900k build. As others here have mentioned in various threads, whatever Pro Tools version/audio interface drivers/plugs/etc that works on 10 also works on 11. Windows 11 is no drama!
Click for audio/video demo
Click for resume
Old 12-02-2022, 07:57 PM
Timothy A. Timothy A. is offline
I use Pro Tools Studio 2022.10. I installed Windows 11 several weeks ago. With Windows 10, my 003 worked great. After Windows 11 installed, my 003 console no longer works, except as a basic sound card. People saying it should work on Windows 11 if it previously worked on Windows 10 are drawing an incorrect conclusion. I have tried to get the 003 working again, but it will not work, and none of the Windows 11 updates have helped. I just tried Pro Tools with Windows compatibility mode, and it still does not get the 003 to work. I deleted the 003 audio driver and reinstalled, but still not working.
Old 12-11-2022, 01:23 PM
Try changing the firewire driver. When I had my 003(and I ran a console and 2 different rack units over several years with Win7 and Win 10), Avid recommended the Legacy driver, but that never worked for me. The driver that did work was the T.I. Compliant driver.
Old 12-12-2022, 06:06 AM
Thank you for taking the time to reply on this issue. Unfortunately, I am already using the TI driver. I have also tried switching over to the legacy driver. Neither will work. I had no issues at all with the 003 while I was still on Windows 10; however, the same day I migrated over to Windows 11, my 003 stopped working--except as a simple sound card. I also tried reinstalling drivers and reinstalling the 003 software driver. Still no luck. The only software change made prior to the 003 issues was the switch to Windows 11.
I found a post from Presonus dated October 5, 2021, titled, "Windows FireWire (1394) Device Driver Discontinuation Notice." In the notice, it states, "Changes in the Windows 11 operating system prevent the device drivers for FireWire products from functioning as designed."
Since the 003 system is a FireWire (1394) system that is no longer supported by Avid, it appears that Windows 11 means the end for the 003.
Old 10-12-2023, 05:53 AM
enchantedworld enchantedworld is offline
I was in a similar situation a while back when I upgraded my rig to an i9-10900k. My Digi 003c was running smoothly on Windows 10, and I was worried about the same thing. What I found out is that your windows 10 key can actually be used to activate Windows 11 as long as it's a legitimate copy. So, you won't need to buy a new key for Windows 11. As for the Digi 003c, it should work on Windows 11 too, but you might need to check for updated drivers or compatibility issues. I'd suggest doing a bit more research and maybe contacting Digi support to confirm, but you might not need to replace your sound card after all.
Old 10-13-2023, 09:39 PM
Originally Posted by enchantedworld View Post
I was in a similar situation a while back when I upgraded my rig to an i9-10900k. My Digi 003c was running smoothly on Windows 10, and I was worried about the same thing. As for the Digi 003c, it should work on Windows 11 too, but you might need to check for updated drivers or compatibility issues. I'd suggest doing a bit more research and maybe contacting Digi support to confirm, but you might not need to replace your sound card after all.
Avid's last driver update for Windows was April 3, 2014. This is considered a legacy product by Avid, and Avid has been very clear that they have ceased product updates for the 003. The last Windows driver 9.0.8 was only qualified up to Windows version 10. The 003 has motorized faders, and the faders will not work at all with Windows 11. Avid has no updated drivers for this legacy product 2014, and they will not be releasing updated drivers for Windows 11. Avid refers to this as End of Product Life Cycle. The industry has moved on from old firewire drivers and interfaces. My 003 worked fine on Windows 10, but the faders do not work with Windows 11.
Old 11-05-2023, 08:06 AM
Not necessarily as I have a firewire Mbox 2 Pro running on Windows 11 with PT Intro(not the very latest, but the previous version, maybe 2023.3?) and it works fine. I can even route Windows audio thru it, BUT I need to reboot to switch between PT and Windows audio(once one program takes control, the other cannot until a reboot). Plus, I am running off a VIA FW port on the motherboard(and older x58 ASUS board). I fully expected it to not work, but it does Since this is a totally spare setup, I'm looking to sell it
Latest Driver (1.0.13) for Pro Tools | Quartet doesn't work on Windows 10 djpbarry Pro Tools | Duet & Pro Tools | Quartet 3 12-20-2019 01:07 PM
Cant get 003 driver to work on PC nellyslide 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-12-2017 08:58 AM
11R Driver 1.1.7 for PT 10.3 Windows Fezzler Eleven Rack 1 10-20-2016 08:28 PM
Will 10.5.1 driver work with 10.5.2 OS ? driver49 Pro Tools M-Powered (Mac) 0 03-09-2008 11:31 AM
Can't get 002 WDM driver to work jzucker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 44 08-26-2004 01:14 PM
