  #231
Old 09-30-2019, 07:02 PM
jantelis's Avatar
jantelis jantelis is offline
Default Re: NVMe upgrade for Mac Pro 4.1/5.1 Mojave
Has anyone had any luck using an NVME with appropriate pcie adaptor etc on a 5'1 Mac Pro Mid 2010 running High Sierra (latest version, not mojave) looking to use one of these drives and clone over my OS and data via carbon copy cloner, seeing alot of old posts and or posts that mention only mojave, was curious if this worked for anyone in the same os and comp as me
thanks!
  #232
Old 10-10-2019, 02:26 PM
TheFilterLab TheFilterLab is offline
Hi jantelis,
I don’t know for sure but as far as I understand you can’t run NVME drives unless you do the firmware upgrades that require Mojave. I think that you can run AHCI drives with High Sierra though. I’m sure someone else here can verify this.
Take care,
Jared
  #233
Old 10-10-2019, 02:28 PM
Hi everyone
I’ve been following this thread as part of the my upgrade research.
I recently did an upgrade from PT10 HD3 to PT 2019.6 Ultimate HD Native PCIe. I started with a new (old) computer that was upgraded. It’s a 2010 Mac Pro with 12 3.46 cores, and 48 Gigs of RAM. I’ve got it running Mojave.
I’m pretty amazed at the increase in power, and for the most part it’s all working. However, all of this talk about increaseing the speed of the system drive has me curious.
Currently my system drive is a Samsung SSD in one of the SATA bays. I’m considering going the NVME route with a PCIe card. I’m wondering if It’s worth the expense, fan noise and potential for failure to go with the crest card. Or if I just go with the simple cheap PCIe card? I know this will still be much faster than what I have now.
Given Ghostwriter’s experience with the crest card that has me a little nervous. Also, how loud is the fan in the crest card? I have anther system in my studio with an HDX card in it and that fan is annoyingly loud. So if the fan in the crest card is anything like that I don’t think it would be worth the increase in speed for me.
Thoughts?
Thanks,
Jared
  #234
Old 10-10-2019, 11:11 PM
WorldStudios WorldStudios is offline
I have a computer with an HDX card already in it. I noticed no increase in fan noise after installing the crest card, but as you say, the computer is already noisy... I would say go for the simple card. The increase in speed going from SATA (250 mbps) to PCI hosted m2 drives (1500) is so worth it. Going from a simpler PCI adapter (1500) to the Crest (2900) is barely noticeable. It is very much like getting a new iPhone one year after the last one. Sure, it’s marginally faster but you feel like fool for spending that much for that little. :) If money is no problem and you like the opportunity to use two blades in one slot, then by all means go crest!
Johan Bejerholm
World Studios
Sweden
Phone +46707773443
  #235
Old 10-14-2019, 03:13 PM
Thanks Johan,
That's kind of how I was leaning. Thanks for the confirmation. I think that's what I'll do.
  #236
Old 10-16-2019, 12:20 PM
Oliver M Oliver M is offline
thanks!
2009 4,1 Mac Pro here, flashed to a 5,1.
I am running a lot of NVMe drives with an Amfeltec card without any issue.
  #237
Old 10-03-2020, 10:35 AM
hornedrum hornedrum is offline
Hi everyone.
Super interesting thread, thanks for a great read!
I am getting back to ProTools after a 3/4 year hiatus....
I am running Sierra on a MP 5.1 6 core 3.33Ghz, PT 12.5.2, mostly Waves11 plus the odd Plugin Alliance plug etc.
I installed the Lycom DT-120 and system profiler says the blade installed is an Apple SSD SM0256G (which from memory was a Samsung 951 perhaps?)
All running smoothly for a couple of years as a boot drive, so probably no need to change that.
So now I am looking to upgrade my old spinners with SSDs.
The consensus seems to be NVMe, is that an option with Sierra though?
They don't need to be bootable, but I'd probably like one drive for samples and another for PT sessions.
I have no PT upgrade plan but fairly happy with PT 12.5.2 on Sierra.
Might you have any thoughts/recs please?
EDIT: Oh, and one further question, is the heat/throttling still an issue with some people?
I only have the GPU and the Lycom card in the PCIe slots, so shouldn't be too crowded in there. A tiny bit worried that the Lycm has no heatsink, but the blade is never hot to touch.
Thanks in advance! :)
  #238
Old 01-03-2022, 03:30 PM
Ghost In The Attic's Avatar
Ghost In The Attic Ghost In The Attic is offline
I just wanted to thank Darryl Ramm again for all of his help and revive this thread. This upgrade turned out to be a life saver for buying time while the M1 gets sorted. If you haven't read this thread, you should. It may keep you up and running for a few more years.
Cheers,
Ghost
Retro 176 (pair), Pultec EQP-1A (pair), Germanium Comps (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL Fusion, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM92, PCM70... Amps, Amps & More Amps.
  #239
Old 01-05-2022, 06:35 AM
K Roche's Avatar
K Roche K Roche is offline
Originally Posted by hornedrum View Post
Hi everyone.
I had the same machine a Mid 2010 3.33 Ghz 6 core Westmere and was running PTHD Native PCIe card
So If I remember correctly
And the same Lycom blade and a Samsung 951 PCIe (my boot drive)
I also installed a new Metal Capable Graphics card which did have a noisy fan
And then I installed a single dual Crest blade adaptor with two Samsung EVO NVMe 1 TB SSD drives on it which were my PT session storage Drive and My FCPX Projects storage dive
It worked great ..
I ran that until I switched to my current iMac and Avid Carbon interface last Dec.
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
  #240
Old 11-04-2023, 09:41 AM
basslik's Avatar
basslik basslik is offline
Hi everyone. This is great news on the sonettech Mcfiver.
https://www.youtube.com/watch?v=9iIJo-izBFQ
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Mac Pro 2012 -should upgrade to Mojave? Zak7 macOS 5 06-04-2019 07:51 AM
Mojave? hanksinclair Artist Series 3 05-03-2019 03:19 PM
New 8th Gen i7 with NVMe m.2 SSD spock999 Pro Tools 2018 26 02-22-2018 11:47 PM
Bootable Thunderbolt case for NVMe drives (Samsung 950 etc) propower General Discussion 1 10-27-2016 04:11 PM
Intel SSD NVME/PCIe Porn Darryl Ramm General Discussion 0 04-03-2015 02:02 PM
