Old 11-06-2018, 02:44 AM
danyg danyg is offline
Default midi clip color
the coloring basically works. when I use the view "clips or notes" I get the correct color.
When I switch to "block" view all the clips are grey/no color. Is there a way to get the whole block colored in the track color?
Thank you
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32
Old 11-06-2018, 03:03 AM
Stig Eliassen's Avatar
Default Re: midi clip color
Works fine here. What are you display preferences set to?
Old 11-06-2018, 03:36 AM
please have a look to the att.
6 midi tracks with 6 different colors. all blocks are grey.
the note "BA" has the correct color and when I click on the blue "ST" track it indicates that it's blue but again the block-view is grey. The notes do have the correct color though.
My settings are on:
- Midi note shows Vel
- Tracks and Midi Ch
- Track Color
Old 11-06-2018, 03:45 AM
Your MIDI outputs aren't routed. They are set to "none". That will override any color codings/settings on my system.
Old 11-06-2018, 04:12 AM
ah ok, that's on purpose because I use those tracks as visual markers in large sessions. I just tried with an intrument track same result if I don't add any instrument.
In fact I don't want to use audio tracks because I'm on Vanilla (track limit)
Do you have another solution using no resources?
Old 11-06-2018, 04:33 AM
You can use a MIDI port/channel on your interface not in use. If you don't have that, I believe you can create a MIDI "dummy" in your MIDI studio setup. As long as the MIDI tracks are routed to "something", your color settings will be intact.
Old 11-06-2018, 05:19 AM
The Fabfilter Pro Q plugin has a midi input that works for the purpose. I hope it doesn't mess up PT I'll try
Thank you Stig
Old 11-06-2018, 05:26 AM
My pleasure. Hope it works for you. I don't work this way, but it's interesting to hear how others do/like it.
Clip Color Weirdness on 2018.7 CHRIS AIKEN Pro Tools 2018 2 08-04-2018 09:49 AM
Drag clip to track changes clip color in real time? diamondschwin Post - Surround - Video 0 08-31-2017 12:51 PM
Clip color question gopher Getting Started 3 12-11-2013 12:31 PM
Can anyone clarify 1) Midi Track Sizing, and 2) color coding Midi Editor Infiltrator Pro Tools 9 5 01-10-2011 07:53 AM
Control+Option+Command/ Color palate track color KingFish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-28-2007 08:54 PM
