Old 01-11-2018, 09:13 PM
SeventhSounding SeventhSounding is offline
Default Midi notes deleting when editing and writing in notes
Whenever I edit MIDI notes in the MIDI editor, if I copy and paste a note (mainly when editing drums) if the note appears under another note, it causes the note above to delete. Is there any way to fix this? Or is there a reason it does this and there is another way to go about it? I mainly have this problem when editing my what I record from my electronic drum kit. I use Addictive drums 2 and send the midi signals from my Alesis kit into Pro Tools.
Old 01-12-2018, 01:36 AM
Stig Eliassen's Avatar
Default Re: Midi notes deleting when editing and writing in notes
You can click'n'drag to move notes, add Alt key to copy'n'drag, or copy then Alt+M to merge notes.
Old 01-12-2018, 10:04 PM
I'll try that out, also I've been having the problem of some sustain notes holding out forever (I use a sustain pedal with my komplete keyboard) I meant to add that in there as well. If i use a string ensemble or something they sometimes hold out forever until another note kicks in
Old 01-13-2018, 12:38 AM
That could be the VI or the preset. Is it the same for all VIs?
Old 01-13-2018, 05:44 PM
I believe so, i am still a pleb when it comes to midi lol
Old 01-14-2018, 02:34 AM
Have you looked at the sustain controller data on that track?
Quantize Midi - deleting notes Matt Darcy Pro Tools 11 0 04-17-2015 01:49 PM
Writing automation without deleting MIDI notes lostsherb88 Virtual Instruments 1 11-28-2011 05:32 PM
midi regions and deleting notes Shatzer Pro Tools M-Powered (Win) 22 10-25-2011 01:26 AM
Deleting MIDI double notes... Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-17-2006 07:07 AM
Deleting/Copy MIDI notes is not deleting/copying MIDI sustain? Mark_Knecht 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-26-2002 12:29 AM
