Old 04-18-2017, 09:58 AM
EddieJones's Avatar
Default Re: EUcontrol 3.6 Auto-bank to selected track not working?
I tried on v3.5 and v3.6....what version of PT is this on ? (although that shouldn't matter)
Old 04-18-2017, 09:59 AM
simonjewel's Avatar
simonjewel simonjewel is offline
It's on 12.7.1 Mac Pro, 20 gigs of ram running on Yosemite 10:10:5
Mac Pro 2x2.8 ghz Intel Zeon, 20 gig ram, Yosemite 10.10.5, Pro Tools 10,11,12.7.1, Logic Pro X 10.2, UA Apollo 16 quad, UA Octo Pcies, Dangerous Music 2 Bus, Antelope Audio Satori, Lynx Studio Hilo, Neve 542, Neve 511, API 505 DI, Bettermaker CV502. Avid Artist Mix, Avid Artist Control, Softube Console 1 mk11.
Old 04-18-2017, 10:50 AM
simonjewel's Avatar
on checking it seems that 3.3.2 was the last time this function worked properly ... Hope this helps :)
Old 04-19-2017, 07:08 AM
simonjewel's Avatar
Update .... went back to 3.3.2 and it worked as it should .... stopped completely as of version 3.4 and upwards .... very odd
Old 04-19-2017, 09:33 AM
EddieJones's Avatar
Your settings look good so I'm not sure what's going on with your system. Just to check we are talking about the same thing ;-)
When you select a track in PT that is not on the surface, your Artist Control doesn't bank to show the selected track or When you bank using the Artist Control Bank/Nudge buttons PT Mix/Edit windows don't follow ? (Both are working on 3 different systems here and I'm sure others would be complaining loudly on this forum if it was a global thing)
  #16
Old 04-19-2017, 09:44 AM
simonjewel's Avatar
If I select a track in Pro Tools that is not on the surface, the surface banks to it no problem. If I select a track on the surface then Pro Tools does not bank. However if I use the nudge buttons on the surface then Pro Tools does indeed bank along with the surface. It's only if I select a track on the Artist Control that PT doesn't bank, it's really odd! Any other things I could try? It was fine with 3.3.2 ... just something from 3.4 upwards .... Thanks for your help tho
  #17
Old 04-19-2017, 11:18 AM
EddieJones's Avatar
I just tried 3.3.2 and it doesn't do this automatically. As far as I know the only way this has ever worked is if you hold down CTL and then select a track on the surface.
  #18
Old 04-19-2017, 11:22 AM
simonjewel's Avatar
Thanks for that, as a matter of interest what Mac's and OS are you testing on? It seems so strange that it worked completely in 3.3.2 .... nothing has changed since as far as my setup is concerned... it can't be a pro tools problem as it worked fine on the earlier version, it can't be a hardware problem for the same reason that it was faultless on the earlier version also ...it has to be a Eucon issue, something that changed between 3.3.2 and 3.4 and upwards ..
  #19
Old 04-19-2017, 11:24 AM
EddieJones's Avatar
I was testing with PT 12.7.0 on Sierra
  #20
Old 04-19-2017, 11:28 AM
simonjewel's Avatar
Maybe that's the issue then I'm on Yosemite 10:10:5 .... I haven't upgraded my OS as it's been so stable
Auto-bank to selected track not working strangy Avid S1, S3, Dock and Control App 26 08-04-2020 10:48 PM
Auto Bank Selected Track EuControl ver 3.5 with protools 12 Cryos Artist Series 2 01-18-2017 07:43 PM
Auto-bank to selected track does auto-nudge to selected track goran m Artist Series 0 10-16-2013 08:54 PM
Artist Mix Auto Bank To Selected Fixed! Chief Technician Artist Series 13 04-23-2013 02:12 PM
Auto Bank To Selected Track BROKEN in 2.7 sleiweke Artist Series 40 04-16-2013 05:42 AM
