Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Windows
Old 04-14-2017, 11:27 PM
alicia.pizza alicia.pizza is offline
Default Re: I'm trying to record an audio track
Okay I did that and its still not recording /: its all sending to the mixer though
Old 04-14-2017, 11:43 PM
YYR123's Avatar
YYR123 YYR123 is offline
Go to your click....
Let it cycle and make sure you are routing your sounds to the master fader
Do you have a level jumping around on the master fader?
Yes
Then make sure your monitors are hooked up correctly b/c it should be outputting sounds
No
Then your still not routing PT correctly
Fall back and try again.
Also you can post more screen shots.
Is PT express even qualified for Win10?
Daniel
Old 04-14-2017, 11:44 PM
YYR123's Avatar
Disable Quick Punch
Daniel
Old 04-14-2017, 11:45 PM
YYR123's Avatar
Search the manual on quick punch.
It should be off normally
Daniel
Old 04-14-2017, 11:52 PM
Yeah the click is routed to the master fader and so is the guitar track. If I press play, the levels jump on the click and master fader. Everything is hooked up correctly and the sounds are outputting to my speakers. I turned on normal recording and still nothing. It's worked before with these same exact settings
Sent from my SM-G935T using Tapatalk
  #16
Old 04-15-2017, 12:44 AM
YYR123's Avatar
Trash your prefs and try again
Daniel
  #17
Old 04-15-2017, 12:47 AM
YYR123's Avatar
https://www.sweetwater.com/sweetcare...s-preferences/
And double check if express is qualified for win 10 b/c win 10 just got an update a few days ago
Daniel
  #18
Old 04-16-2017, 08:45 AM
do you know another DAW similar to pro tools?
  #19
Old 04-16-2017, 12:13 PM
YYR123's Avatar
Presonus Studio 1
Daniel
  #20
Old 04-16-2017, 01:01 PM
ffarrell ffarrell is offline
Reaper?
Sent from my SM-N920P using Tapatalk
Unable to Record (digitize) a Regular Midi Track to an Audio Track JuicyMusic macOS 9 02-27-2013 08:52 AM
Record 1 audio track, then go to record a second, the timer button flashes... help tdubthatsme General Discussion 5 02-27-2011 04:39 PM
PT 9 won't record audio track SoloMonk Pro Tools 9 9 12-13-2010 10:04 AM
how to record audio from aux track badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-15-2003 08:57 AM
How do I record a MIDI track onto an audio track? shemcom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-11-2003 06:13 AM
