Old 02-04-2016, 05:28 PM
sfsonarboy sfsonarboy is offline
Default Some UAD plugs "failed to load...not valid 64 bit AAX..."
Greetings, I'm using a fresh install of Pro Tools 12 on a new Windows 10 box witha RME Fireface UC soundcard. I just uninstalled/reinstalled UAD software because I noticed some of my older UAD plugs were missing (UAD Teletronix LA-2a Legacy, UAD UA 1176LN Legacy...) and on application start am getting error "The following plug-ins failed to load because they are not valid 64 bit AAX plug-ins". From everything I read in various newsgroups and vendor sites, these should be OK.
Can you advise how I can get around this error and have PT recognize these plugs?
Noting when I initially installed a couple weeks ago, I don't recall if at the time I agreed to "Move to Plug-ins (Unused) folder" or not. I'm at that screen again, and hopeful for a reply here before I respond either way.
Big thanks in advance for your help!!
Steve E
Old 02-04-2016, 05:43 PM
Shatzer Shatzer is offline
Default Re: Some UAD plugs "failed to load...not valid 64 bit AAX..."
That happened to me upon upgrading to 8.5. I reauthorized the plugins and they worked properly right after.
Old 02-04-2016, 05:52 PM
sw rec sw rec is offline
First make sure you have the latest UA installer...then just run the installer again. Mine did exactly the same thing, works fine now.
Old 02-04-2016, 05:55 PM
Awesome, that did the trick (I had thought to re-install UADs, but not to just reauthorize). Huge thanks Shatzer for the quick and excellent reply!!
HTML code is On
Boot Screen "Not Recognized Video Hardware Connected", "video engine failed to init bcrichguitar macOS 3 04-01-2012 09:10 AM
"Unable to load class:"TPopup" Kirby B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 07-01-2010 05:47 AM
Pro Tools HFS+ / Macdrive Error "Not a valid Audio volume for recording" theaero 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-30-2009 11:13 PM
"no valid network adaptor is available for video satelite connections " message nachonieto Pro Tools TDM Systems (Win) 4 03-30-2009 04:51 PM
ProTools 8 Fxpansion VSTs "The plug-in failed to load" balveniediggz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-27-2008 09:30 AM
