Old 01-28-2014, 02:13 PM
farmfresh farmfresh is offline
Default 11.1.2 on Mountain Lion bugs bugs bugs. command+f, elastic audio, discoloration
So many problems with this. STAY AWAY FROM 11.1.2 until these are fixed, unless I'm the only one having these problems which seems unlikely.
1. command+f will always crash PT
2. elastic audio freezes
3. screen gets oddly colored, I'm not sure what causes that, could be related to activating the "all" group
4. Getting lots of 6101s, could be unrelated, never happened before.
5. CPU meter 3 times as high in 11.1.2 than in 11.0.2 with the exact same session open. For example, in 11.1.2 recording 32 tracks at 96k at buffer of 128, "Channelstrip" on every channel, sets the CPU meter at about a bouncy 15% with big spikes every 20 seconds or so, and will occasionally stop recording.
EXACT same setup, same session even, on 11.0.2 the CPU is a rock solid 11%, no spikes, no bouncy CPU meter.
In fact, with 11.0.2 I'm streaming 2 HD movies, typing this, and batch processing a bunch of files in Wavelab while recording 32 tracks at 96k with 5 stereo sends and plug-ins on every channel. No spikes, CPU meter super stable.
In 11.1.2 I can't even open up a browser while it's running or it will spike like crazy and shut off
I've done clean installs of each version, multiple times, to check myself, unless someone convinces me otherwise it seems like an issue with 11.1.2
On the plus side "shift+1" now turns the all group off/on in 11.1.2!
Absolutely NONE of these problems occur in 11.0.2, so I'm going back to that.
Would like to have these fixed in the next release, total showstopper problems here.
Thanks!
Late 2012 mac mini i7
16 GB ram
10.8.4
Orion32 (I know CPU spikes have been an issue in the past with this)
Old 01-29-2014, 11:19 AM
dj_grimmace dj_grimmace is offline
Default Re: 11.1.2 on Mountain Lion bugs bugs bugs. command+f, elastic audio, discoloration
I've been getting a lot of random cpu overload issues in 11.1.2 as well. I can't seem to pin point anything specific. At first I thought it was a Massive VI bug, but that ended up being a coincidence. I opening up a lot of sessions where several cores are registering around 25% usage, only to find minutes later without any major changes or added plug ins that those same cores are now maxed out. Really bizarre. Perhaps a memory leak somewhere?
PT HD Native 11.3.1
Windows 7 sp1, Intel i7-4770 @3.4 gh
32 gigs ram
PT 11 HDN
Omni
Old 01-29-2014, 11:38 AM
Farmer Dave Farmer Dave is offline
I checked all these on my system and am not seeing any of these in 11.1.2.214 (at least not here)
10.8.4
11.1.2.214
10.3.8.378
2.66 Ghz Quad-Core Intel Xeon
16GB RAM - 1066 MHz DDR3
Audio Hardware - Coreaudio Aggregate MOTU HD Express & 828mk3 Hybrid
ATI Radeon HD 4870:
NVIDIA GeForce GT 120:
H/W Buffer - 512
Disk Cache- Normal
Can't check this one....
Old 01-29-2014, 12:01 PM
Thanks for checking on that Farmer Dave, what is most weird is that you aren't getting the command+f crash or elastic audio freezing. Bizarre!
Old 01-29-2014, 02:37 PM
Sure thing!
I tried both "Command F" (not sure what this does) and "Command Shift F" (for searching in the clip bin) with no adverse effects.
I use Elastic Audio a LOT in all my sessions as well, and would've come across that one in a heartbeat.
Old 01-29-2014, 07:42 PM
mrtomcat mrtomcat is offline
I have been having very similar issues, with audio suddenly dropping on some tracks and then it's back. Also a dramatic amount the 6101 error
After reading this I went back to 11.1.1 and everything behaves dramatically better again
Old 02-11-2014, 01:00 PM
nathanaelj83 nathanaelj83 is offline
I have been experiencing (what seems to be) a similar typing related issue - during memory location creation.
When I create new locations, PT just crashes. After seeing all these posts about "Command+F" and "Shift Key" crashes, I started trying to replicate the issue, still to no avail... However still experiencing some strange behavior:
I tried pressing command+F during memory location creation and nothing happened at first. So I named the marker, hit "Return" to exit the memory location window and another window for the same marker number immediately re-appeared. But everything I typed was gone, and the marker I just created was not appearing in the Memory Locations window. Definitely some strange instabilities happening. I hope a solution is found soon. Also hoping my VO sessions this week aren't going to get all messed up on account of these issues.
Anyone else having the memory location crash?
OS X 10.8.5
PT 11.1.2 HD Native Thunderbolt (Omni)
The only peripheral plugged in other than the Omni is a USB Hub with an Oxygen 25 and DVD Burner.
Bring your production house to the Midwest!
Old 02-12-2014, 08:26 AM
IveGotTricksUpMySleeve IveGotTricksUpMySleeve is offline
i think the update is only good for 10.8.5 if i remember correctly
if you're on 10.8.4 i think you need to update
just don't update to mavericks by accident because that's worse
i see one guy on here who's using 10.8.5 and still having issues but that's with pt11 HD
I'm running it on the vanilla version and it's running fine..
I also got 16 gigs of ram so that might help to
Old 02-12-2014, 10:50 AM
clausiii's Avatar
clausiii clausiii is offline
Cmd+F works fine here, Elastic Audio as well, but i also get more 6101 errors too.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 02-12-2014, 03:25 PM
roberts roberts is offline
11.1.2 crashes 10.8.4 I had to go back to 11.0.2
Avid seems to have little interest in fixing issues with 11.
Delay Compensation shrewd
Video Engine Screwed
Workspace Window Screwed
Memory Leak with Dynamic Plug-in processing
Too many 64 Bit AAx plug-ins in you Pro Tools 11 will stop your PT 10 from launching.
NO PT 10 in Mavricks!
these are not minor problems they MAJOR *ucking issues!
002/003 Mountain Lion driver bugs darkgoob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-26-2013 10:34 AM
More Elastic Audio bugs midnightrambler Pro Tools TDM Systems (Mac) 13 06-29-2009 03:02 PM
importin audio+video-bugs clusterer Post - Surround - Video 1 06-08-2007 04:46 AM
Bugs in my box - no, REAL BUGS !!!!!!!!! Mixtrix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-25-2006 06:33 PM
Audio Suite Bugs out on preview NickFLZ Pro Tools TDM Systems (Mac) 5 08-21-2000 10:29 AM
