Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Windows
Old 09-22-2014, 06:59 PM
Chosen Chosen is offline
Default Re: Pro Tools Express can't locate hardware.
Hello Everyone. I'm having this same issue "Unable to locate hardware" error when I attempt to open Pro Tools.. I have Pro Tools Express 10.3.4 with the Mbox. I downloaded the latest updated driver to try and fix the issue as recommended on the forum post but I am still getting the "Unable to locate hardware" error when I attempt to open Pro Tools. I have uninstalled and re-installed the program, checked to make sure the Mbox is functioning properly through the device interface and it is. Are there any other suggestions?
Old 09-22-2014, 08:07 PM
Southsidemusic's Avatar
Hi and welcome to he community
Try holding down the "N" key while opening PT and chose the MBox and see if that helps anything.
Best of Luck
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 01-19-2015, 11:37 AM
kklein2014 kklein2014 is offline
I just had this problem and then found the solution, at least for me. I'm using Windows 7 and Pro-Tools, M-Powered Essential. The program comes with the KeyStudio set that includes a midi keyboard and microphone/headphone USB dongle. Downloading all of the latest drivers and the latest release of the program did not solve the problem. The problem was that Windows was not recognizing the Fast Track driver; apparently it is part of the M-Audio microphone/headphone dongle that comes with KeyStudio. I went to Device Manager, where the dongle was listed as USB Device. I decided to update the driver. I did a manual selection (automatic just installs the same one), selected M-Audio, and then FastTrack, which I had already downloaded and installed. Beautiful, it worked! Apparently it doesn't get applied for some reason. Hope this helps. I thought maybe the KeyStudio keyboard was required, but no, it runs without it.
Old 01-22-2015, 06:44 AM
llerrem llerrem is offline
Hey KKlein, would you be able to break this down a little further. This looks like the exact info I need. Just not sure how to do it. I'd appreciate it!
Old 07-09-2017, 10:08 AM
Time2paint Time2paint is offline
Please help me~
I also have the "Unable to locate hardware" error with
Protools Express 10.3.4
I've installed (and uninstalled) Asio 10,13,14, because none worked.
My Equip:
DigiDesign MBox2, (driver is active)
64 Bit Processor
6 core Processor
Windows 7
iLok 2nd gen (driver is active)
Thank you to all the wonderful tech-savy young people - you are great.
Pro Tools Express - Windows 8 - Unable to locate Hardware - Mbox Mini protoolsexpress Windows 1 02-15-2014 12:56 AM
MBox Mini UNABLE TO LOCATE HARDWARE Pro Tools Express electropunkboy macOS 4 11-18-2013 09:06 PM
Pro Tools Express Unable To Locate Hardware Psychic Denim FireWire & USB Audio Interfaces (Win) 1 06-21-2013 07:00 AM
Pro Tools Express 10.3.3 unable to locate hardware cfmfam Getting Started 2 05-16-2013 05:09 PM
Mbox3 Pt express "Unable to locate Hardware" FMviolin Pro Tools 10 0 04-27-2013 12:46 PM
