Old 04-16-2013, 05:00 PM
Thumbs up Artist Mix Auto Bank To Selected Fixed!
Thank you AVID for fixing the auto bank to selected bug with the Artist Mix surface. That was a really quick turnaround between the time I reported the issue and v2.7.1 was released. You have made one of the mixers I work with very happy.
Old 04-17-2013, 05:44 AM
Audioartist Audioartist is offline
Default Re: Artist Mix Auto Bank To Selected Fixed!
I wish they were as quick with the fixing of the EQ page not always showing.
(Problems after show/hide tracks and after switching layouts also if you duplicate a track, the duplicated tracks EQ doesnt show and if you add a new track, the EQ on the track before that wont´show.)
Old 04-17-2013, 06:48 PM
Question Re: Artist Mix Auto Bank To Selected Fixed!
On which surface?
Old 04-18-2013, 03:24 AM
Thats strange.. it´s only on the artist mix, not on the artist control.
The control behaves differently, if I select a track without EQ plug-in and then after that select a track with a EQ, I have to hit the EQ button again.
On the artist mix, hitting the EQ button, it latches, and that seems to be the cause.
If I de-select EQ on mix surface before changing layouts, duplicating, deleting, show/hide tracks, it will find the EQ plug-in without having to de-activate/re-activate the EQ.
It´s a workaround, but if I forget to de-select EQ, it seems to crash a lot easier.
Old 04-18-2013, 03:30 PM
Lightbulb Re: Artist Mix Auto Bank To Selected Fixed!
Please search protools.ideascale.com for this issue, and if it is not posted, please post it as a bug.
Old 04-20-2013, 11:59 AM
priorytools priorytools is offline
I'm sorry , , but can I just clarify this banking "bug" .
With the mix window open in Pro Tools, on the Artist/MC Mix you hit the bank right button. .
In the Pro Tools mix window we see the blue surround on 8 channels' track selection boxes move to the next 8 channels to the right. . Fab. . let's keep hitting the MC/Artist channel bank button & we see the same result until the channels go off screen to the right . . The screen doesn't jump to the right to keep the select 8 channels in view. . as it does with say Pro Control .
V boring . .
Any chance this will change ?
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 04-23-2013, 07:10 AM
Emcha_audio's Avatar
Worked on a Artist Mix the other day and was sorry to see that this was a happening too. Felt weird not to see the mix window move on the second screen. But then again when I have a control surface I rarely look at that screen although I do see it from the corner of the eye.
Manny.
Wave-T.com
Old 04-23-2013, 07:27 AM
southboundloco's Avatar
southboundloco southboundloco is offline
if i'm not mistaken this feature is NOT implemented with the Artist Series...WHY? @!#$ knows...
Pro Tools 11.2
Pro Tools 10.3.9
REAPER
MPTK2
ProFire 2626
Benchmark DAC1
Neumann KH 120 A
Avid Artist Mix
ASUS Sabertooth Z77, Intel i7-3770K CPU OC'[email protected], 32 Gigs RAM
Mac OS X 10.9.3 Mavericks
Old 04-23-2013, 08:54 AM
No clue, maybe it's going to be implemented with eucon 3.0 Let's hope.
Manny.
Wave-T.com
Old 04-23-2013, 09:06 AM
Works with a command 8 though . .
Mix Window Follows Bank Selection - Artist Mix HowlingWolfStudio Pro Tools 11 4 01-17-2014 09:48 PM
Auto-bank to selected track does auto-nudge to selected track goran m Artist Series 0 10-16-2013 08:54 PM
Auto Bank To Selected Track BROKEN in 2.7 sleiweke Artist Series 40 04-16-2013 05:42 AM
Avid seriously, when will the Edit Window Follows Bank Selection function be fixed?! Focuret Pro Tools 10 1 11-23-2012 02:04 PM
Edit window - everything selected bug still not fixed! Marsdy macOS 1 11-02-2012 10:48 AM
