Old 03-22-2011, 10:03 AM
brianjanthony's Avatar
brianjanthony brianjanthony is offline
Default Import Session Data Midi not working?
Since moving to Pro Tools 9, when I import midi session data into a new session, all the tracks always revert to 96... not the volume they were at in the original session. This is even with the proper checkboxes checked in Import dialogue.
Is it just me? Or is this a known issue.
Its a killer because I always end up opening the last session to check the settings. Makes the Import function useless.
brian
Brian
www.brianjanthony.com
MacPro 6 core 3.46 Cheese Grater
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
TDM user way back. PT user since 98.
I'm either working, sick, or both.
Old 03-22-2011, 12:47 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Import Session Data Midi not working?
brian
Hello Brian,
I just tested import session data, importing midi tracks and it imported them at the levels they were set to.
There's no automation to set the level etc so it seems to be working ok here on 9.0.2
Chris
Producer, Engineer,
www.ukmastering.com
[IMG] code is Off
Import Session Data NOT WORKING!! shanex100 Windows 1 12-23-2011 03:27 PM
Import session data (+consolidate) or Compacting not working SD2 Pro Tools TDM Systems (Mac) 7 09-26-2007 11:22 AM
Consolidate option in Import Session Data not working SD2 Pro Tools TDM Systems (Mac) 4 07-09-2007 08:27 AM
Consolidate option in Import Session Data not working SD2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-05-2007 03:32 AM
Import session data MIDI track out of time propower Pro Tools TDM Systems (Mac) 1 03-01-2006 12:35 PM
