Old 01-27-2003, 11:00 AM
[email protected] sound@nwfilm.org is offline
Default Shuffle Mode, regions locked but Automation moves anyway, Why?
Any ideas on how to lock the automation with the region so it doesn't move in shuffle mode? I can't find a preference for this.
I've worked with two systems, one operating on OS 9.2 with PT 5.3.1 (HD) and one on OS 9.1 with PT 5.1.1 software (24Mix). I lock all but one of the regions in a track and then, while in shuffle mode, edit that one region. Placement wise, the regions behind the edited region don't move, but their automation does. How to prevent this? Thanks!
Wayne
Old 01-27-2003, 11:09 AM
Noiz2 Noiz2 is offline
Default Re: Shuffle Mode, regions locked but Automation moves anyway, Why?
I had a friend have this problem but when she tried to demonstrate it she couldn't get it to happen??? But it was obvious that it had happened, automation that fit the regions were out of sync with the regions they obviously were coneccted with. So I'm very interested in the answer, I'll be an "expert"
www.scottkouesound.com
SK
Old 01-29-2003, 02:19 PM
I'm going to bump this.
Digi have you got an answer or work around???
SK
Old 01-30-2003, 01:50 PM
zeeman zeeman is offline
bump
cmz
MAC OS 13.6.1
Mac Mini M2 16gig Ram
PT 2023.12
Lynx Aurora 16n Thunderbolt
Old 01-30-2003, 03:33 PM
DigiTechSupt's Avatar
Wayne,
I was unable to reproduce this on 5.31 when seperating regions and deleting parts of the unlocked regions. The only way I could get the automation of the locked regions to move was to seperate the unlocked region and snapped the first half of the region to the end of the region before it. This caused the automation of the locked regions after it to move. Is this the same behavior your seeing?
Regards,
Mike
Avid Audio Tech Support
Support FAQ
Old 01-30-2003, 03:43 PM
Wayne,
Regards,
Mike
Support FAQ
Old 01-31-2003, 12:12 AM
Originally posted by DigiTechSupt:
Wayne,
Regards,
Mike
<font size="2" face="Verdana, Arial">What about 5.1.1 le? That's where I saw it.
SK
SK
Old 01-31-2003, 05:12 AM
dkrz dkrz is offline
This is very easy to reproduce, (currently running LE 5.2).
Lock two adjacent regions and draw some automation under the second one in the timeline. Unlock only the first one, select trimmer tool and shuffle mode. Trim the first region in then out again by a different amount. Now, look at the automation. It gets all screwed up and out of place. Every version of PT I've ever used has this bug. From TDM 5.0.x to LE 5.2.x
The only safe way too use the trimmer tool in shuffle mode is to use it ONLY on the last region in the timeline since it only effects automation residing AFTER the edit area.
dk
www.dpksound.com
Old 01-31-2003, 10:48 AM
Hello,
This issue has been logged and will be looked at by engineering. Thank you for the information. To prevent the automation of locked regions from moving, I would suggest not editing in Shuffle mode if you have locked regions in the timeline that exist after the region you are editing.
Regards,
Mike
Support FAQ
Locked out of Shuffle Mode Slim Shady 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-29-2016 09:43 PM
Midi regions in shuffle mode MEAT Pro Tools TDM Systems (Win) 0 10-10-2008 07:41 PM
Shuffle mode locked?!?!? ichbin Pro Tools TDM Systems (Mac) 2 07-23-2008 06:22 AM
Shuffle Mode Locked - How to turn off? toddamo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-07-2008 09:05 AM
Shuffle mode "locked" - ??? Bonestown Pro Tools TDM Systems (Mac) 3 07-04-2007 03:51 AM
