Old 08-15-2010, 07:21 PM
lpbaker lpbaker is offline
Default Core audio - sound stuck in endless loop
OSX10.6.4, PT8, Mbox 2
In System Preferences I set the sound output device to be the digi core audio device (ie: for all normal system audio, not just PT). It works fine for a while, but then it will suddenly lock up and whatever sound it was playing will keep looping over and over (it's about a one-second repeat cycle). The only way to stop it is to unplug the Mbox from USB entirely.
Any suggestions why it's locking up like this?
Thanks,
Lindsay
My art and animation can be seen at http://www.LPBaker.com
Old 08-15-2010, 08:03 PM
lincol1 lincol1 is offline
Default Re: Core audio - sound stuck in endless loop
No tellin' - Digi Core Audio driver's have had issues before - what pops out at me is that 10.6.4 is not yet qualified - might have something do do with it.
Lincoln Mitchell
www.studiofifty.net
Mac Pro 2.66 Ghz Quad, 10.6.6, 12GB Ram, PT9, Logic 9, Kontakt, East West, VSL, Waves, Sound Toys, IK Multimedia
RME FF UC, Focusrite Octopre mkii, UA LA 610 mkii, MC Transport, Yamaha HS80M, Lauten, AKG, Sure, Blue
Old 08-16-2010, 02:25 AM
arneal arneal is offline
A less drastic solution that works for me - actually, I don't get this problem since the 8.0.4 upgrade - is to open Audio MIDI Setup (while PTLE is still running) and from the Clock source drop-down menu, select S/PDIF. Usually the audio immediately begins to play normally. After a few seconds, I toggle back to Internal and that does it. This periodic hiccup used to occur so often, that I kept my Audio MIDI Setup utility in the dock. As I said, this doesn't happen since I upgraded from 8.0.3. to 8.0.4. Hope this helps.
21.5" (Late-2015) 11,2 iMac i5 2.8GHz, 16Gb, PT 12.8.2, Metric-Halo ULN2 2d Exp'd w/Sierra 10.12.6
Old 08-16-2010, 02:34 AM
Good to know it's not just me. The 8.0.4 update wasn't in my available downloads list but I've found it now, will install that and see if it's resolved.
Thanks,
Lindsay
Old 08-22-2010, 09:50 PM
Just following up -- since installing the 8.0.4 update I've had no more problems :)
Thanks,
Lindsay
Old 08-23-2010, 08:03 AM
Molto bene!
Core Audio Manager stuck at 48 khz for third party apps Sadie Tango Pro Tools 10 8 01-13-2014 06:10 PM
Activating my PT9 to PT10-PT11 upgrade is an endless loop? mike_mccue Windows 1 06-23-2013 03:45 PM
Updated to 8.0.1 LE and Core Audio Manager is stuck at 48 khz Sadie Tango 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 60 10-21-2012 12:50 PM
Bounce to Disk creates endless loop boneboy Pro Tools TDM Systems (Mac) 2 08-13-2006 08:05 PM
Need Help with endless loop Mark Manela Pro Tools TDM Systems (Mac) 1 05-28-2002 04:27 PM
