Re: Hooking up regular speakers to 003
Wow.. those are pricey.
Nothing wrong with using them as a mix reference... but in the long run, you'd be better off dropping a few more coins on a more accurate set of nearfields. Good luck- |
And they are not designed to be near-field. If you room is huge and you can put them way back, it might work. I have my monitors about the same distance as my LCD, but they are designed for that. If you mixes are consistently bad on reference systems, then I think it is likely your mixing room causing the problem. Does your mix sound significantly different on cans compared to the Events? Is your mixing room treated? Is your home theater treated?
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
Try that and see how your mixes translate to the HiFi set.
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
Far out man. |
This is a problem that I have worked on with every project! Get every thing sounding good in PT, burn a disk, and find that its all to dark, deep , muddy, ect. Over the years I have developed EQ settings for each instrument I use (more for keyboards and sound modules, live and vocal not so bad). Getting to know your room and monitor speakers is the most important part of creating music, (other than creating good music of coarse)!! I found the car to be the hardest,,,, get it right for your car,,,, and the other two (boom box & home stereo) sound real bad!!??? So when you finaly get it right for all three, well time for a party!! The only other option is to get it close, and then send it off to a professional Mastering house.(not so cheap)!! Good luck!,,,,,, and have fun!!,,,, Mike
#16
how about using both? hook your events to the main out, and your amp to your hi fi in the alt monitor out and toggle between two speakers. it's good to have real world check aside from you flat speakers.
#17
Hooking up both is a good idea, using the commercial audio speakers as a reference.
I have the same problem, sounds great in the studio, dark and muddy on the CD, particularly in my car. My problem is my room and monitors - I'm constrained on space. Originally, I had used a commercial portable audio system for monitoring my mixes and masters. Then I picked up a Hafler amp and two Event 20/20;s. While technically more accurate, the Hafler/Event combo resulted in a worse final product. This is because the accuracy of your amp and monitors doesn't mean anything if your space isn't set up properly. In a perfect setup, you'd have near, far and mid field monitors in a properly arranged and treated room. This is not always possible in home studios. In these cases, a consumer-grade audio system for monitoring may be better because it boosts the highs and lows (particularly the lows in my case.) You need to find a setup that works for your space. You may need an inaccurate monitoring system to artificially boost some frequency ranges. I've just hooked my old monitoring system and will use it as a reference in conjunction with my Hafler/Event combo. I'm hoping it helps! Nice to see that others have this issue.
----------------------------- Wango Don’t piss down my back and tell me it’s raining. http://www.soundclick.com/bands/defa...?bandID=851389 |
#18
I'm hoping somebody can help me with this..
Can a pair of digital Genelec be connected to the 003R SPDIF output? If yes, how would I control the volume?
Check out my page Goldnhour Acoustic Solutions https://www.instagram.com/goldnhour_acoustic/?hl=en |
#19
2029A Digital Active Monitor - Genelec.com …with S/PDif inputs, just connect them to the S/PDif outputs on the 003. I guess they would have volume controls on the back, but just create a master fader in PT for the 003 spdif output, and you have the volume control. And you'll be bypassing the 003's DA converters, and be using the ones in the Genelecs instead.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
hooking home speakers to mbox pro 2 factory | kamron12345 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-28-2010 09:23 AM |
DEBATE: Using other speakers and crappy speakers to check mixes! | DJ Hellfire | Tips & Tricks | 15 | 06-03-2010 08:46 PM |
Connecting regular computer speakers to ProTools? | spicyitaliano | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 01-07-2006 09:14 AM |
How play regular sounds through DIGI-connected speakers? | Ron Cook | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-21-2003 07:20 PM |
Hooking up 5.1 speakers from ProControl | babyseal | ProControl, Control|24, Command|8 | 0 | 03-29-2000 08:33 PM |
