Old 12-10-2008, 11:49 PM
GtrDude GtrDude is offline
Default Hooking up regular speakers to 003
So far I've been using monitors by Event.
They're OK but I have much better speakers in my living room.
I would like to hook those up to the 003, or do what ever it takes to be able to listen to my PT sessions using them. Ideally to monitor as well.
The speakers I'm talking about have a regular + - input and are not powered.
How can I use my living room speakers with the 003 Factory?
Thanks
GD
Old 12-11-2008, 12:22 AM
erthquake erthquake is offline
Default Re: Hooking up regular speakers to 003
You could use the RCA outputs on your 003 and connect them to any RCA inputs that are on the receiver/amp that's powering your living room speakers. However, you really shouldn't use those living room speakers for monitors when recording and mixing. They're probably hyped in the top and low end, and that'll cause your mixes to have too much midrange.
Old 12-11-2008, 12:36 AM
pianosound pianosound is offline
I agree of coarse with erthquake, but it is cool to have a larger, deeper sound now and then just for visitors to listen to, and this could be the cheaper way to do it (if you have an unused sterio amp laying around,,,, like the one in your living room!!??)
But for mastering a project we need the cleanest sound we can afford, and even then it takes burning a lot of CD's and trying them on home stereo, boom box, and car stereo, and making adjustments untill you get to know your speakers well! (I've been out in my car at 2:00 AM listening to tracks). have fun,,,,,,,,,,,,, Mike
Old 12-11-2008, 03:58 AM
GTBannah GTBannah is offline
Originally Posted by GtrDude View Post
.... I have much better speakers in my living room. ....
GD
They are not "better" by a long shot. They were made for a different purpose and are not as accurate as the Events. As the other chaps said, don't use them for work, only to impress your friends.
Derrkins
GuyBarTola
PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!!
Old 12-11-2008, 07:44 AM
JMS40 JMS40 is offline
No...
The RCA's on both the 003 and 003R are SPDIF digital connections, not analog audio.
Old 12-11-2008, 07:57 AM
getz76 getz76 is offline
Use your home speakers for referencing, but not for mixing.
How are your monitors currently set up? What is their position? Are they on any isolating material? Is your room treated at all?
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 |
| Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 |
Old 12-11-2008, 09:52 AM
Originally Posted by JMS40 View Post
No...
Doh! My bad. Didn't look at the 003 picture close enough. J's right. The OP might be outa luck then.
Old 12-11-2008, 09:59 AM
Could use the 003 main outs.
Old 12-11-2008, 10:04 AM
.... or a "send and return" from the headphone output.
Derrkins
GuyBarTola
Old 12-11-2008, 11:20 AM
Well the speakers are Martin Logan Spire and in my opinion sound much smoother.
My main problem with the Event's is that the top sounds rather harsh and overly bright.
Other than that I could use them just fine.
As a matter of fact when I have finished with my mixes and they sound good coming out of the Event's and the 003 they always sound much too dark in all other stereo systems. Including mine. Which is a fairly expensive and accurate system.
hooking home speakers to mbox pro 2 factory kamron12345 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-28-2010 09:23 AM
DEBATE: Using other speakers and crappy speakers to check mixes! DJ Hellfire Tips & Tricks 15 06-03-2010 08:46 PM
Connecting regular computer speakers to ProTools? spicyitaliano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 01-07-2006 09:14 AM
How play regular sounds through DIGI-connected speakers? Ron Cook 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-21-2003 07:20 PM
Hooking up 5.1 speakers from ProControl babyseal ProControl, Control|24, Command|8 0 03-29-2000 08:33 PM
