Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 08-17-2008, 08:03 AM
Matt Darcy Matt Darcy is offline
Default Elastic Audio - Markers not appearing after analysis
Hello Guys,
I'm trying to use elastic audio to correct some timing issues.
I've been watching an introduction video recommended on the forum, which seems really good.
I'm now trying to apply what I've learnt in the video to practice, but it would seem I'm missing something obvious.
I've selected a track made from a recording of an acoustic guitar, I've told selected the Elastic Audio polyphonic plugin, great, track flashs grey for a second (analysis) then returns to nomal. I've put the track into tick mode, expecting to see marker points from the analysis, but I don't, I simple see the wave form, in the normal colours almost as if analysis failed.
Am I missing something obvious/step ?
thanks,
Matt
Old 08-17-2008, 08:06 AM
Stig Eliassen's Avatar
Default
Have you switched to analysis view? You should. Warp view will be "empty" at this stage.
Old 08-17-2008, 09:57 AM
Stiff Stiff is offline
Default
I think what you need to do is find out what warp and analysis view really are. It's in warp mode that you do the stretching.
Daily news & reviews
www.ProToolerBlog.com
Old 08-17-2008, 10:32 AM
Default
then I should be able to see the analysis markers (according to the video tutorial I'm using)
Old 08-17-2008, 11:52 AM
Default
Yes, you should see the event markers in analysis view. If you don't, select the region(s), go to Region -> Elastic properties, and make sure Event sensitivity is set to 100%.
Old 08-18-2008, 05:37 AM
Default
Now that part makes sense,
but as I'm understanding the tutorial when I select a track for analysis by enabling the elastic audio tools that should put me into "analysis mode"
which it doesn't seem to be doing, so how do I manually enter analysis mode after selecting a track for analysis ?
I think I'm missing a key bit of information here that I'm not picking up from the tutorial.
thanks
Old 08-18-2008, 07:24 AM
Default
The same way you view block, waveform, volume, pan, etc in the edit window...warp and analysis can be found in the same list for each track.
Old 08-18-2008, 09:03 AM
Default
perfect,
thats exactly what I was looking for, thank you very much.
Copying Elastic Audio Analysis Markers to Another Track BEN6732 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 06-22-2020 02:44 PM
Elastic Audio: Create Warp Markers From Analysis Gatekeeper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-07-2018 07:45 AM
Beat Markers Appearing As Elastic Audio Markers Fabdickson Pro Tools 9 1 03-06-2012 05:03 PM
Elastic Audio not showing Analysis PRS4LIFE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-10-2008 09:25 PM
Elastic Audio Analysis Weirdness Rotter3* Pro Tools TDM Systems (Mac) 2 11-15-2007 06:42 AM
