Old 06-01-2008, 01:37 PM
almon almon is offline
Default No signal via ADAT Optical
Unable to get an audio signal in to protools via ADAT Optical.
I connected optical cables and verified connection, setup I/O and hardware to ADAT optical,
set session to 48kHz, selected ADAT input on each track, press play on source and still no signal.
I also attempted to change clock soure to OPTICAL but PT would not allow.
System---------
Digi 002R
PT 7.4
MAC DUAL CORE G5 (NOT INTEL)
-2GB RAM
Old 06-01-2008, 08:14 PM
andydunham andydunham is offline
Default Re: No signal via ADAT Optical
What are you using through the optical cable? I have a motu 8pre and my 003 shows the ADAT connection, the tracks are record enabled, channel assignments are correct, and STILL it doesn't show a signal until... I turn the volume knob on the 8pre. I know, it sounds kind of ridiculous, but I read that turning the volume knob can actually do the trick and so far it's worked flawlessly for me. Not sure if this will help you, but I thought I'd suggest it.
Old 06-01-2008, 08:35 PM
Slim Shady Slim Shady is offline
That usually means something isn't connected right.
Old 06-02-2008, 10:43 AM
I am connecting a MOTIF ES8 keyboard.
I have the volume turned up on he motif still no signal.
I have also tried reconnecting with a new optical cable and still have no luck.
Old 06-02-2008, 11:26 AM
stoneinapond stoneinapond is offline
System---------
Digi 002R
PT 7.4
-2GB RAM
This is a guess (since I don't own the Motif) but is the optical output of the Motif two-channel S/PDIF?
If so, you need to select S/PDIF as your clock source and make sure your input assignement matches up. I am not in front of my system right now, but I believe S/PDIF input defaults to channels 17/18.
Stereo signal through ADAT Optical? soundboy35 Post - Surround - Video 6 12-24-2010 03:18 PM
Clock Issue on 192 i/o Optical [ADAT] Not Optical [Encl] Willard Pro Tools TDM Systems (Mac) 1 10-10-2007 01:23 PM
can't get input Optical (ADAT) signal in 002R mnstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-19-2004 09:13 PM
ADAT optical vs TOSLINK optical (vs COAX) cc1 Pro Tools TDM Systems (Mac) 4 06-15-2004 06:02 AM
whats the difference between adat optical and spdif optical? Vegadark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 04-07-2002 07:42 PM
