Old 05-12-2008, 07:03 PM
rowchar rowchar is offline
Default 003 clocking problem
Hi Guys............my 003 will not work at 64 samples in PT 7.3.1. Works great at 128 and above but no 64. Any thoughts, ideas??
Thanks.
Old 05-12-2008, 07:49 PM
spkguitar's Avatar
Default Re: 003 clocking problem
What sample rate are you using for your sessions?
Old 05-13-2008, 12:42 AM
I am doing my sessions at 48k sample rate - 24bit resolution. Is it normal to not be able to use
64 samples at that sample rate and resolution on an 003?
Old 05-14-2008, 10:24 PM
Bump..............
Old 05-19-2008, 10:31 PM
I am doing my sessions at 48k sample rate. Any ideas on why I can't use the "64" setting?
Old 05-20-2008, 12:31 AM
mano111 mano111 is offline
Actually the topic name shoud be "Unable to work at 64 buffer size" + the error numbe you are getting. you can also search that error number on the Digi site.
We need to know more about your system. please post a sandra report MOBO, chipset, CPU, RAM, FW card HDs ...
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
Old 05-21-2008, 10:44 AM
Thanks for the input. I updated to PT 7.4 cs4 and now I can use the "64" buffer setting!
WHEW............ Thanks again.
Clocking Problem???? mybrother 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-12-2010 01:09 PM
Clocking problem with 96 i/o DonovanBomb Pro Tools TDM Systems (Mac) 0 08-14-2007 07:27 PM
Strange clocking problem? locosoundman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-03-2005 06:21 AM
Clocking Problem Fix... Bastiaan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-14-2003 12:17 AM
Clocking problem? Please help kurt Pro Tools TDM Systems (Mac) 4 09-11-2002 12:03 AM
