Old 07-05-2007, 03:38 AM
SD2 SD2 is offline
Default Consolidate option in Import Session Data not working
Hello everyone,
(I've already posted this in the LE section but since it also happens under HD I thought I could "double-post"... Sorry if I wasn't supposed to)
I've noticed a very strange behaviour lately. When importing tracks from one session to another using the Import session data option, checking the "Consolidate from source media" option (+handle size) doesn't seem to do anything.
Once imported, regions on the tracks are not consolidated using the defined handle size.
They can be trimmed way past this handle size...?...
I've tried different handle size (from 1000ms to 0) and made tests using different sessions and tracks, it won't work.
I've also tried the "Copy from source media" option just to see what happened and it gets weirder.
I've tried importing a 30 minutes files edited to a 10 seconds region, using both "Copy" then "Consolidate" (50ms handle size).
With the "Copy" option, I do get the 10 sec region that I can trim up to 30 minutes.
Now, using the "Consolidate" option, the resulting 10sec region can be trimmed up to 2minutes 26seconds!... ?...
I don't get it. I've tried with shorter files with the same result.
Any Idea?...
Setup: G4 2x1,25/10.4.8/PT 7.3.1cs3 + HD3 (192I/O)
AND: I get the same problem on a Digi002-10.4.8-PT7.3.1cs3
Pro Website
Administrator of Brotools, free online tutorials for the french Pro Tools user.
Old 07-05-2007, 08:00 AM
SD2 SD2 is offline
Default Re: Consolidate option in Import Session Data not working
Just coming back to say that several users (and friends) did the test for me. It doesn't work with their setup too!
They have different PT versions (7.1, 7.2 and 7.3) and all of them encounter the same bug.
I've made further tests and found that the Consolidate option works when importing OMF files... Go figure.
Digi?
Anyone?
(I would specially be interested if a 6.9 user could make the test)
Pro Website
Old 07-05-2007, 03:18 PM
SD2 SD2 is offline
Up?
Pro Website
Old 07-06-2007, 12:52 AM
SD2 SD2 is offline
Is noone interested in that matter?
I mean, is nobody else using Import and consolidate options??
I do think this is a serious and very time wasting bug and really wish for an answer here, at least from Digi.
Is that one of the "known issues"?...
Pro Website
Old 07-09-2007, 08:27 AM
DigiTechSupt's Avatar
SD2 -
If you're looking for an answer directly and promptly, you may want to use the email Tech Support Request form, as we do not always see every post that is made here.
With that - this issue has been logged for a fix.
Avid Audio Tech Support
Support FAQ
Assertion line 123 error when trying to import session data/consolidate tracks 6foot4design macOS 5 06-20-2012 06:20 AM
Import Session Data NOT WORKING!! shanex100 Windows 1 12-23-2011 03:27 PM
Import Session Data Midi not working? brianjanthony Pro Tools 9 1 03-22-2011 12:47 PM
Import session data (+consolidate) or Compacting not working SD2 Pro Tools TDM Systems (Mac) 7 09-26-2007 11:22 AM
Consolidate option in Import Session Data not working SD2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-05-2007 03:32 AM
