Editing without moving automation moves
Sometimes when I do audio cut, paste, trim, slide editing, the volume automation for a particular sesction stays in place. More often than not it doesn't. How can I keep my volume automation moves with the partiicular secction they were set for. Re drawing is time consuming. Thanks, Ty |
Re: Editing without moving automation moves
deselect Automation Follows Edit
Operations drop-down I think nice pic w/ the 816
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
By deselecting auto follows edit, no automation data follows my edit. That's the exact opposite of what I want.
Even when the auto data is supposed to follow the edit, it doesn't on my machine. Ty Ford |
I know that if you drop a region from the Regions List onto a track, the automation at that point doesn't change. Or if you have tempo changes, automation on a tick-based track might change its relationship to an audio region.
I did a series of experiments to see if I could figure it out, because it seems like I remember having trouble with that several months ago with 6.x. But now, as long as Automation Follows Edit is checked, I can't get it to not follow it, no matter what mode I'm in (Shuffle, Slip, etc), and regardless of the settings of Link Timeline & Edit, Link Track & Edit, and Timeline Insertion Follows Playback. I tried every combination of those in each of the four modes, using copy-paste, cut-paste, trimming, and sliding. Automation followed the edit in every case, with the exception that when trimming in a mode other than Shuffle, the automation didn't get trimmed. But that's not a problem. I'm using 7.0. Maybe it's yet another 7.1 bug? Unless you need one of those few esoteric things that were fixed between 7.0 and 7.1, go back to 7.0 and see if that fixes it.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Hey, wait a minute. How much memory do you have assigned to automation in prefs? Maybe there's just not enough to handle it right.
Ty Ford
With respect, maybe you could give us your Pro Tools version. filosofem
Aaron Mulqueen - 001 HD Native |
Respectfully, 7.0 PTLE.
Ty |
Ty, have you tried any of the "Special Cut/Paste/Copy" commands?
filosofem
no
Next! ...I'm out.
It seems weird that sometimes it works and other times it doesn't. System reinstall? Maybe someone with some brighter ideas will chime in. Good luck. filosofem
AUtomation moves still not following file moves | Ty Ford | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-05-2006 01:19 PM |
Automation Moves Occur Late | nob turner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-27-2006 10:34 AM |
waves plugs bump on automation moves... | tomcat | Pro Tools TDM Systems (Mac) | 2 | 07-11-2004 01:47 AM |
Shuffle Mode, regions locked but Automation moves anyway, Why? | [email protected] | Pro Tools TDM Systems (Mac) | 8 | 01-31-2003 10:48 AM |
duplication of Automation moves from 1 item to another | georgia | Post - Surround - Video | 2 | 06-14-2001 06:49 AM |
