Old 01-19-2006, 01:20 AM
clusterer clusterer is offline
Default ADR - cueing-beeps...
hi there,
i wonder how you guys are using cueing-beeps while ADR? i´m dubbing sentence for sentence. before each sentence i often use a 1 sec. long beep - with its end, the sentence starts exactly. in most cases the narrator can get a long with it...
mostly if i´m muting production-audio after having the narrator listening to it often enough i´ll reach better results... what does your narrators have included in their hp-mixes while:
- ADR for same language
- ADR for other languages...
thnx a lot!
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD
Old 01-19-2006, 06:55 AM
Sonsey Sonsey is offline
Default Re: ADR - cueing-beeps...
Hey there...
I use the "traditional" film 3 beep - that's 3 beeps 1 frame long 1 foot apart (set PT to feet/frames mode). The talent starts on the missing fourth beep (3...2...1...). I find most actors work fairly well with this - although it drives some to distraction so I will turn it off if I see it's not working for them. I find with ADR the real trick is to make your talent as comfortable as possible - do they want the guide on or off? Do they want the beeps? Do they like the talk-back on or off? And so on. Always results in a smoother session and generally better ADR - especially since ADR can be a traumatic experience for those actors who aren't used to it. Some will take to it like a fish to water, others... well patience is a virtue in ADR session
"Ya canna change the laws of physics..."
-Montgomery Scott
Howard Sonnenburg
Atomic Audio
Ottawa, ON
Canada
Old 01-19-2006, 07:21 AM
mampam mampam is offline
If you do a lot of ADR check out Gallery Software's "ADR Studio". It is wonderful.
Old 01-19-2006, 08:51 AM
thnx for infos! much appreciated them!
greets!
Old 01-19-2006, 07:05 PM
We do this too, and we have a small box with a light in it that we trigger with a MIDI message that corresponds to the beep. The note on goes to a MIDI Solutions relay and closes the relay to turn on the light. Its like a streamer, but not on the screen.
Old 01-19-2006, 07:10 PM
spigots spigots is offline
Not a hi-jack
I am completely ignorant on "streamers". See the term occasionally. Have done a couple of late-night insomnia driven searches
it's obviously a visual timing cue
but
what is it, and why do people use it?
Thanks in advance
Old 01-19-2006, 07:44 PM
Craig F Craig F is offline
in the old days it was grease pencil on the work print
this is the most noted of the electronic versions:
http://www.webcom.com/auricle/
if there is/was no other audio you need some form of visual cue to let you know were to punch-in and/or preform
Thank you,
Craig
Old 01-19-2006, 07:50 PM
minister's Avatar
minister minister is offline
FWIW, i use the count down beeps 3,2,1 ... as well. works great.
streamer: it is a vertical or slanted line that moves across the frame (film or video), that gives you, yes, a visual timing cue. this is easier for some people and in some situations. often when recording the music, some section will be done to clicks, a digital metronome, for a tempo pasages. free timing music uses punches or streamers. punches are multiple holes punched in the film or, electronically, on videotape. these produce a short sequence of fluttering lights pulses on the screen. the conductor is cued into these preperatory signals for the beginning of a cue or scene or a barline within a cue.
similarly, a streamer could be used. this helps guide the conductor to start a cue or sync point within the cue as s/he watches the streamer travel accross the screen. they work with 3 foot, 4 foot, or 5 foot or 6 foot streamer, being 2, 2-2/3rds, 3-1/3rd and 4 seconds in travel time. with 3 foot being the most commomn, scribed onto the film. obviously, on video, it is done in seconds, and inserted electronically. the composer and conductor get together with the music editor to discuss the various techniques that will be used. sometimes streamers are used to indicate where a change in tempo will happen, even if you are recoding to a click.
on the score, it is indicated with a -------------------------------| over the passage where the streamer starts and stops. (punch marks look like this +
the streamer travels from left to right across the screen. when it hits the right edge of the screen, you are on cue, the "dead cue"
to scribe it on the film, they used to use streamer boards. these could be made out of yardsticks. you taper it from the top edge of one side to the bottom edge of the other. they would hinge two boards together so that the top one was tapered left to right and two fasteners at the top and bottom held the film in place. they would mark the frame of the "dead cue" - the start of which was at the bottom. then they'd scribe a line with a nail punch or nail set. sometimes they'd put a punch at the end of the cue. like victor borge reading punctuation shhoooPUT! the nice thing about the punch at the end is it is visible even if you keep your eyes on the score or script.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 01-20-2006, 02:37 AM
steppenwolf68 steppenwolf68 is offline
back to the original question:
in my experience ADR differs a lot from country to country.
From what I know in the States the beep only (3-2-1-go) is very common for as in Germany for example actors expect the beeps AND some sort of visual streaming or countdown. Usually the actors lines have to be taken manually and put into the DAW whereas in other places like France the lines are displayed as subtitles on the screen. Though I like ProTools very much it is definetely not made to do ADR. It was designed to do music production in the first place and the post part of it has been added later.
I know "ADR Studio" and it's ok but honestly compared to what we had with ADR capabilities of AUDIOVISION (on a MAC 9600 !) it's going back in time...
Old 01-26-2006, 12:01 PM
matchoo0 matchoo0 is offline
Hey Chief,
Cool technique with the midi controlled cue light. Is that the Midi solutions R8? What exactly is the small box with with the light in it? (Brand/model)
Thanks
Matt
HTML code is On
From MAc to PC: ADR Cueing software and soundminer gsilbers Post - Surround - Video 5 11-10-2011 10:42 AM
Cueing Mac and Xp pro tools le 7! plz read DukeDiddy89 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-16-2011 12:46 PM
Cueing ProTools tracks. jaman4fun VENUE Live Sound Systems 4 10-27-2009 07:09 AM
Cueing Headphone Mixes - how?? mixit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 12-20-2004 05:52 PM
Error Cueing DV Machine InnoForm Media Pro Tools TDM Systems (Mac) 6 05-09-2004 09:56 AM
