Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Windows
Old 07-13-2017, 02:52 AM
live83 live83 is offline
Default Express - Can't locate hardware
Hi guys,
I wanted to test times per tools compared to ableton live, however, says pro tools that it does not find an audio interface! At ableton live 9 is the asio driver synonymous impeccably? Where is the error?
System:
SiSoftware Sandra
Nr
Hostname : Ableton9
Arbeitsgruppe : WORKGROUP
System
Modell : ASUS All Series ASUS MB
Serialnummer : System Serial Number
Gehäuse : Default string Desktop
Hauptplatine : ASUS X99-DELUXE II
Serialnummer : 160571264400169
BIOS : AMI (OEM) 1601 02/22/2017
Intel vPro : 9.01.37.1002
Gesamtspeicher : 32GB DIMM DDR4
Prozessor(en)
Prozessor : Intel(R) Core(TM) i7-6800K CPU @ 3.40GHz (6C 12T 3.86GHz, 3GHz IMC, 6x 256kB L2, 15MB L3)
Sockel/Slot : FC LGA1150
Chipsatz
Speichercontroller : Intel Xeon (Broadwell-E) DMI2 99MHz
Speichercontroller : Intel Xeon (Broadwell-E) Memory Controller 0 - Target Address/Thermal/RAS 99MHz, 4x 8GB DIMM DDR4 2.64GHz 256-bit
Speichercontroller : Intel Xeon (Broadwell-E) Target Address/Thermal/RAS 99MHz
Speichermodul(e)
Speichermodul : Kingston/Micron KHX2666C15D48G 8GB DDR4 PC4-21300U DDR4-2666 (15-17-17-35 7-60-20-7)
Grafiksystem
Monitor : Samsung SyncMaster
(1920x1080, 7.2")
Monitor : Samsung U28E590
(3840x2160, 27.7")
Grafikkarte : NVIDIA GeForce GTX 960 (8CU 1024SP SM5.2 1.13GHz/1.39GHz, 1MB L2, 2GB 6GHz/7GHz 128-bit, PCIe 3.00 x16)
Grafikprozessor
CUDA GP-Prozessor : NVIDIA GeForce GTX 960 (1024SP 8C 1.13GHz/1.39GHz, 1MB L2, 2GB 6GHz/7GHz 128-bit)
OpenCL GP-Prozessor : NVIDIA GeForce GTX 960 (1024SP 8C 1.13GHz/1.39GHz, 128kB L2, 2GB 6GHz/7GHz 128-bit)
Compute Shader Prozessor : NVIDIA GeForce GTX 960 (1024SP 8C 1.13GHz/1.39GHz, 1MB L2, 2GB 6GHz/7GHz 128-bit)
OpenGL Prozessor : GeForce GTX 960/PCIe/SSE2 (2GB)
Physische Speichergeräte
Corsair Force GT (60GB, SATA600, SSD) : 56GB (F:)
SanDisk SDSSDA240G (240GB, SATA600, 1.8", SSD) : 224GB (G:)
WDC WD5000AADS-00S9B0 (500.1GB, SATA300, 3.5", 32MB Cache) : 466GB (D:)
Samsung SSD 950 PRO 256GB (256GB, PCIe1/3x4/NVMe, SED) : 238GB (E:)
Samsung SSD 950 PRO 256GB (256GB, PCIe1/3x4/NVMe, SED) : 238GB (C:)
Ultra Fit (16GB, USB3/NVMe) : 15GB (H:)
Logischer Speichergeräte
OCZ 60GB (F:) : 56GB (NTFS, 4kB) @ Corsair Force GT (60GB, SATA600, SSD)
San Disk (G:) : 223GB (NTFS, 4kB) @ SanDisk SDSSDA240G (240GB, SATA600, 1.8", SSD)
X-Ableton (E:) : 238GB (NTFS, 4kB) @ Samsung SSD 950 PRO 256GB (256GB, PCIe1/3x4/NVMe, SED)
Festplatte (C:) : 237GB (NTFS, 4kB) @ Samsung SSD 950 PRO 256GB (256GB, PCIe1/3x4/NVMe, SED)
ESD-USB (H:) : 15GB (FAT32, 8kB) @ Ultra Fit (16GB, USB3/NVMe)
Festplatte : 450MB (NTFS, 4kB) @ SanDisk SDSSDA240G (240GB, SATA600, 1.8", SSD)
WD500 (D:) : 466GB (NTFS, 4kB) @ 2x WDC WD5000AADS-00S9B0 (500.1GB, SAS/SATA300, 3.5", 32MB Cache)
Peripherie
LPC Hub Controller 1 : ASUS Wellsburg LPC Controller
Audio Gerät : PNY High Definition Audio-Controller
Audio Codec : nVidia 0072
Audio Gerät : 6656 Universal Audio Apollo Twin Thunderbolt
Laufwerkscontroller : ASUS Wellsburg 6-Port SATA Controller [AHCI mode]
Laufwerkscontroller : Samsung NVMe SSD Controller
USB Controller 1 : ASUS Wellsburg USB xHCI Host Controller
USB Controller 2 : ASUS Wellsburg USB Enhanced Host Controller #2
USB Controller 3 : ASUS Wellsburg USB Enhanced Host Controller #1
USB Controller 4 : 8738 DSL6540 USB 3.1 Controller [Alpine Ridge]
USB Controller 5 : ASUS ASM1142 USB 3.1 Host Controller
USB Controller 6 : ASUS ASM1142 USB 3.1 Host Controller
System SMBus Controller 1 : Intel ICH SMBus
System SMBus Controller 2 : Intel MCP5-E(P) XMB Ch 0 SMBus
System SMBus Controller 3 : Intel MCP5-E(P) XMB Ch 1 SMBus
Drucker- und Faxgeräte
Drucker : Send to Microsoft OneNote 16 Driver (1200x1200, Farbwiedergabe)
Drucker : Microsoft XPS Document Writer v4 (600x600, Farbwiedergabe)
Drucker : Microsoft Print To PDF (600x600, Farbwiedergabe)
Drucker : Brother PC-FAX v.3 (200x200)
Drucker : Brother MFC-J4510DW Printer (600x600, Farbwiedergabe)
Drucker : Brother Generic Jpeg Type1 Class Driver (600x600, Farbwiedergabe)
Scanner und Kameras
Scanner : Microsoft Brother MFC-J4510DW [30055c0f79d3] (Scanner, USB)
Scanner : Brother MFC-J4510DW LAN (Scanner, 2400x2400, USB)
Peripherie
Media Player : SanDisk Ultra Fit (14.89GB)
Betriebssystem
Windowssystem : Microsoft Windows 10 Privat 10.00.10586
Kompatibel mit Plattform : x64
Asus Deluxe II Mainboard
Intel Core i7-6800K
32 GB Ram
UAD 2 Solo PCIe
UAD Apollo Twin MK II Thunderboldt
Arturia Minilab MK II
Arturia Drumbrute
Moog Minitaur
Maschine JAM
Windows 10 64 Bit Version 1511
Ableton Live 9 Suite
Pro Tools First
Old 07-13-2017, 06:11 AM
Southsidemusic's Avatar
Default Re: Express - Can't locate hardware
Try launching PT with the N key held down and when popup window comes up choose your interface there and see if that helps.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Pro Tools Express can't locate hardware. apoltorak6 Pro Tools Express on Windows 14 07-09-2017 10:08 AM
Pro Tools Express cannot locate MBox2 hardware Victorzk Windows 2 11-03-2014 07:30 AM
Pro Tools Express unable to locate hardware Sven80 Pro Tools Express on Mac OS X 1 06-03-2014 12:59 PM
Pro Tools Express Unable To Locate Hardware Psychic Denim FireWire & USB Audio Interfaces (Win) 1 06-21-2013 07:00 AM
Pro Tools Express 10.3.3 unable to locate hardware cfmfam Getting Started 2 05-16-2013 05:09 PM
