Avid Scorch
Avid Scorch (iOS) Forum
Scorch Forum Home Page
Forum Terms of Use
Scorch for iPad Support FAQ
Avid Scorch
Go Back   Avid Pro Audio Community > Other Products > Avid Scorch (iOS) Forum
Register FAQ Calendar Today's Posts Search
Old 08-27-2013, 01:59 PM
Sam.Butler's Avatar
Sam.Butler Sam.Butler is offline
Super Moderator
Post Avid Scorch 1.2 Now Available
I am very pleased to announce the release of an update to our iPad app, Avid Scorch. This release includes:
  • Open MusicXML files
  • Support for Retina Displays
  • Share scores via email*
  • Print to compatible AirPrint printers*
  • Adjust staff size in the score
  • Display Tempo in beats per min
  • Also includes many fixes to crashes and other stability improvements
(*=not available with scores purchased from the Scorch Store)
The update is available through the iTunes App Store. For more information, click here.
After updating to the new version, you may find the cover art for the example scores is not at the full resolution. This is due to the older version of the graphic still being in use. To resolve this, delete the old example scores and then restore them from the Avid Scorch Settings.
To delete the old example scores:
  • From the Scorch Shelf, touch Edit, delete the scores you want to update and touch Done
To restore the new versions of the example scores:
  • Quit Avid Scorch
  • Go to the Settings app and select Avid Scorch
  • Set Restore default scores to On
  • Re-open Avid Scorch
The cover art for scores purchased in the Scorch Store will remain at the lower resolution until the publishers updates the graphics on their servers. Once this is done, you can delete the scores and redownload them by doing this:
  • From the Scorch Shelf, touch Edit, delete the scores you want to update, and touch Done
  • Tap Scorch Store and go to Purchases
  • Sign in if you need to and when you see all the scores you have purchased, tap Redownload
Sam
Old 08-30-2013, 08:04 AM
billunatic billunatic is offline
Default Re: Avid Scorch 1.2 Now Available
THANK YOU!!!!!
I have been waiting for this update, and bug fix!!
I can once again search my scores rather than scroll like a madman!!!!!!
Thank you!!!!!
Old 06-12-2015, 07:13 PM
swingaroux swingaroux is offline
Staff Size is not working for me on an iPad 2. I have cleared working memory, still no luck. It was working, a month ago. My iPad is IOS 8.3, 64GB, with 19.2 GB Available. Have there been any other suggestions with regard to getting Staff Size to work?
Avid Scorch Store gianluca.cherubini Avid Scorch (iOS) Forum 24 03-13-2013 04:22 PM
Help Avid Scorch App not working with my new Ipad Mixmaster D Avid Scorch (iOS) Forum 1 06-06-2012 05:37 AM
What is wrong with Avid Scorch. Wheat Williams Avid Scorch (iOS) Forum 5 09-06-2011 06:49 AM
Is Avid Scorch CoreMidi aware? Shawn12 Avid Scorch (iOS) Forum 1 08-11-2011 01:57 AM
