Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 01-18-2021, 06:59 AM
Elien Elien is offline
Default Two bugs with Eucontrol?
I am using Eucontrol with the Control App and an Artist Mix to control Cubase 11 on Windows.
Two issues:
1) I created a user defined soft key with a sequence of commands: EUCON Addtrack;... a couple of Key-Commands with a final "Return" key command. This does not work, the timing seems to be the problem since the behaviour is "random" (sometimes some of the key Commands are performed partially, sometimes not). The funny thing: If i do the "same" but start with a key command that oppens the add track dialogue everthing works. So a mixture Of Eucon and Key commands in a command-sequence does not work (any more).
2) When I switch to the "tracks" view in the control app the system hangs up with the error message "Number of allowed hardware... exceeded". This crashes Eucon and Cubas 11. It only happens when activating the tracks view in the control app.
Old 01-19-2021, 11:13 AM
EddieJones's Avatar
Default Re: Two bugs with Eucontrol?
The first sounds you need the add delay between commands feature we have planned. Hopefully next release.
Where is that error coming from EuControl or Cubase, this sounds like an issue we reported to them a few weeks ago. Hopefully they will fix soon.
Artist Control new breaking bugs with Eucontrol 2019.12 Oli_W Artist Series 4 01-06-2020 07:12 AM
EuControl 18.3.0.219 has bugs home_studio Artist Series 8 03-23-2018 10:05 PM
11.1.2 on Mountain Lion bugs bugs bugs. command+f, elastic audio, discoloration farmfresh Pro Tools 11 21 05-01-2014 07:21 PM
3 EUControl bugs + 1 crash bug OS X 10.6.4 Intel geoffb Artist Series 1 10-03-2011 01:21 AM
Bugs in my box - no, REAL BUGS !!!!!!!!! Mixtrix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-25-2006 06:33 PM
