Old 07-28-2003, 09:54 PM
CraigD CraigD is offline
Default Ableton Live 2.1 as Rewire Slave in Pro Tools 6.1???
Does anyone know the best way to run Ableton Live 2.1 and Pro Tools 6.1 together? I've been told that most people run Ableton as a Rewire Slave in Pro Tools. Is that the way to go?
I installed both Pro Tools 6.1 and Ableton Live 2.1 today. I fired up Pro Tools 1st, then Live. Live showed up in my Inserts section, just like it was supposed to. When I set it to stereo I heard the outputs of Live coming into my Digi002. It was Great!
I'm just a little confused on where to go from here. What are the possibilities? I'm not sure if I grasp the whole concept of Rewire. I've been saying that I would like to be able to separate tracks in Live directly to Pro Tools for editing. I think this is what Rewire is all about, but I'm unsure how to do this.
Any tech. heads out there that got this whole Rewire thing down and can help a brother out?
Thanks!!!
Old 07-29-2003, 02:06 AM
reynep reynep is offline
Default Re: Ableton Live 2.1 as Rewire Slave in Pro Tools 6.1???
its simple - midi goes out of protools into live and audio comes back from live into protools................. i think - ive never used it.
Old 07-29-2003, 07:06 AM
yes yes is offline
You'll find the skinny on it right here...
http://www.ableton.com/index.php?mai...iveandprotools
There are many ways to work with Live. One way is to assign a PT insert for each bus out of Live and process tracks with ProTools Plugs. Use soft synths/samplers in PT.
Very powerful combo.
Cheers,
J
http://www.strayvoltage.net
Old 07-29-2003, 07:16 AM
Cool.
I read that article and it was helpful. I just have to figure out how to assign the output of different tracks in Live to the input of different tracks in Pro Tools.
I see that Live is accesed through the Inserts in Pro Tools and that you can pick Stereo L & R or Bus 1-16. I just have to find out how to assign the tracks in Live.
If anyone has any insight, please let me know.
Thanks Again!
Old 07-29-2003, 03:36 PM
yes yes is offline
When Live is open in Rewire Slave mode, in the Mix window on each track you will see a little pull down menu that says MASTER. If you click on it you will see a list MASTER, BUS 3/4, BUS 5/6, ETC.
Choose your outs to PT here.
In PT choose the appropriate on each aux track you assign to LIVE.
Cheers,
J
Ableton Live rewire slave into PT workflow vudoo Pro Tools TDM Systems (Mac) 5 10-18-2015 05:33 PM
Pro Tools HD 10.3.5 and Ableton Live 9.0.4 Rewire not visible SouthFresh macOS 8 05-25-2013 10:43 AM
Live won't run as ReWire Slave. Tim R. Pro Tools TDM Systems (Mac) 2 06-05-2005 08:05 PM
...need some help with ableton live as PT LE slave dlae Tips & Tricks 3 11-08-2004 04:03 AM
Ableton live as a ReWire slave in PT6.1? EvenAce 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-28-2003 07:06 AM
