Old 04-06-2012, 08:07 AM
Brandonx1 Brandonx1 is offline
Default Can I use a maco with 2 eucon commands?
I'm just now delving into macros. I'm able to use one eucon command with keystokes and whatever but I'm not able to use a second eucon command in the macro. So, I want to disable volume automation
(eucon), punch automation (key stoke), and then enable volume automation again (eucon) all in one key stroke. I'm not able to program the second eucon command. Is this possible or did I miss something?
Thanks
Old 04-06-2012, 09:28 AM
robertg robertg is offline
Default Re: Can I use a maco with 2 eucon commands?
Thanks
I'd like this feature as well, I don't understand why it's not possible.. one of the strengths of eucon was supposed to be stackable commands.
Old 04-06-2012, 01:04 PM
The golfer The golfer is offline
Unfortunately you can use only 1 eucon command at a time in a combined command.
Serge Hamel
Mixer / Sound Designer
http://www.netpostproduction.com
http://immersivesoundvr.com/
Old 04-07-2012, 07:54 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
I wonder if there's a way to "trick" the .xml into doing this. It's at least SHOWING that there are multiple EuCon commands but I don't think it's firing multiple commands.
<Control DELAY="250" FREQ="1000" ID="SoftKey12" RepeatEntry="True" TYPE="SmartSwitch">
<Label FONT="Arial Bold" FONTSIZE="12.0000" NAME="Automation Test" NOTEXT="1" TYPE="Text"/>
<CommandSet SUBTYPE="OneShot">
<Command ID="1" TYPE="EuCon">*/Automation/Write Enable/Enable Volume Automation</Command>
<Command ID="1" TYPE="EuCon">*/Automation/Punch Capture</Command>
</CommandSet>
EuControl Screenshot Here
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
EuCon Commands missing from Editor! TimNielsen Artist Series 9 10-27-2016 06:36 AM
Eucon commands not stackable? robertg Artist Series 5 12-15-2011 10:15 AM
No Eucon commands visible in Eucontrol software 2.6.2 (Win7 64bit, PT 9.0.5) Elmobe Artist Series 0 11-23-2011 02:35 AM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 12:01 PM
Alert - EuCon 2.5.6 is only for Pro Tools 9 and EuCon DigiTechSupt Artist Series 11 02-24-2011 10:25 PM
