Is there any way to flip faders (aux and main channel faders) to have a larger fader to control minut headphone changes between separate headmixes (aux sends) those dam faders are so TINY !!!. thanx
Edit > De-select "Narrow View".
I do believe Sdesign wants to flip the sends down to his main faders, and this is not possible without a console.
You can use aux tracks for cue mixes by bussing audio tracks via sends, and route the outputs of the cue auxes to your headphones. I sometimes do this since I still haven't found a way to control my sends via the Frontier Tranzport.
I do think you undersand........... thank
you So as as no one else knows no WAY ?? |
![]() Quote:
Here's an idea for a convoluted workaround that might work. You can click the send (when not in view send X mode) to bring out a full sized fader for the aux send in a floating window for more fine control of level and riding of the aux send. I believe you can shift-click on others to bring more send faders up like this simultaneously. Then you could manually arrange them on your screen in order to be like a separate mixer for headphone mixes. After you get them arranged the way you want - save it as a window layout preset - lather, rinse, repeat for other aux sends. I think you can even import these from other sessions, so you could save a session as a template to import these window sets from. Give this a try and let me know if it works. I'm curious.
Mac Pro 2010 12-core 32GB / High Sierra / Avid HDX / 192digital / 96io (2x) / Pro Tools Ultimate 2019.5 / D-Command 40 fader / www.studiocrash.com |
I have tried this before - the way you explained........... it was a little better but it was a pain in the butt to put together and maintain ............ we have so much monies wrapped up in all of this ......it will take another year before I can replace present console with an icon or like. I appreciate your input.
If you hold down the apple button while you move the slider, it allows you to enter finer resolution changes on any fader or control on the Pro Tools mixer. That should make those small changes easier to tweak.
Steve
Steve Shepherd Extreme Mixing |
MC Control Fader Flip for Sends | AMIEL | Artist Series | 4 | 10-01-2012 12:22 PM |
Feature request: Pre Fader Sends follow Main Faders | PeterScherr | Pro Tools 9 | 13 | 06-11-2011 08:59 PM |
Where are sends F-J on the MC Control for PT HD8 fader flip??? | snake doc | Artist Series | 3 | 07-29-2010 08:47 PM |
Foldback sends mirror Mix window main faders? | turnyouritch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-03-2010 12:13 PM |
Flip Sends to Fader | kimlau | ICON & C|24 | 2 | 01-14-2009 09:37 AM |
