Old 12-27-2005, 04:08 PM
hodge hodge is offline
Default do you use pre amps with your mbox ?
Im a noob to recording, and was wondering if i should use a preamp when recording vocals or guitar ?
Old 12-27-2005, 05:39 PM
Default Re: do you use pre amps with your mbox ?
Your Mbox is a preamp. Nothing else is needed unless you want the "flavor" of something like a tube preamp or some direct box that adds to your sound. Microphones go to the XLR inputs while insruments like keyboards or bass/guitar(direct) go to the quarter inch inputs. I believe there is a switch on the front for mic/line so select according to what you need to work.
Old 12-28-2005, 08:21 AM
ok cool thats what i thought. I read somewhere that someone was using another pre amp, so i wasnt sure. Thanks..
Old 12-28-2005, 10:48 AM
ondruspat ondruspat is offline
As Albee said other pre amps than your Mbox's can be used to "flavor" your sound. The Mbox lets you select XLR, line, or instrument. Generally a pre amp will use a 1/4" cable into the Mbox, which would then be set to "line". A word of warning, a pre amp could overload the instrument level setting.
I found that the Mbox pre's are almost too clean for my tastes, which also means that they are very good pre amps. Lately I've been using an old Scully pre into the Mbox for vocals, and my SWR750 as my pre for bass.
"Sometimes having limits keeps you sane"- Albee1952
Mbox 3 Pre amps vs. External Pre amps? evanbgrove 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-10-2011 05:21 AM
Mbox 2 pro... Pre Amps (vs) 003 Pre... Amps Norm Mix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-24-2009 02:37 AM
mBox pre amps Kia43 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 03-03-2006 03:43 PM
Mbox And mic pre amps jpd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-10-2003 08:19 AM
The Pre-amps on MBox is amazing J. Guerrero 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-10-2002 12:48 AM
