Go Back   Avid Pro Audio Community > Live Sound > VENUE Live Sound Systems
Old 09-27-2020, 03:59 AM
chamikalak@gmail.com chamikalak@gmail.com is offline
Default S3L X AVB device not showing in iMac
I have S3L-X system using in my band and we are using the same system for doing our Studio recordings as well. Once in a while, once a recording is done and shutdown the system for the day and when we power on the system it gets unrecognized from iMac but the network works fine. In the mean time S3 surface could be connected as EUCON device but not as AVB device.
We are confident that we always follow the startup guidelines as per manual .Only solution we identified is to reinstall MAC OS. We had this issue around 5 times over last few months.
When the issues arises if I disconnect the network cable and reconnect it to a Macbook, system works as expected.
Is there anyone who faced a situation similar or related ?If so please share your experience. Anybody has a solution for this other than reinstalling please kindly share your thoughts and ideas.
Best regards
Chamika
System
iMac (Retina 5K, 27-inch, Late 2015)
CAT 6
S3L-X with Two Stage Boxes
V4.6.1.4
MBP - 10.14 (Mojave)
Old 10-19-2020, 04:46 PM
RyanJ's Avatar
RyanJ RyanJ is offline
Default Re: S3L X AVB device not showing in iMac
It's an OS issue, the AVB applications and preferences can get corrupted in the OS, and the OS itself blocks itself from fixing it. To fix this issue, disable SIP
Reboot the mac while holding Command R
Once it boots into recovery mode
Open Terminal from the Utilities Menu
Type csrutil disable hit enter
Type reboot hit enter
enjoy
Ryan John
Principal Product Manager | Avid Live Sound
ryan.john@avid.com
MIDI device not showing up in peripherals nibtgom Pro Tools 11 1 09-20-2017 12:59 AM
Mac not showing HD native as input device K Roche Pro Tools HDX & HD Native Systems (Mac) 38 08-02-2015 07:27 PM
003 Drivers not showing up in Device Manager zedhed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-25-2014 04:46 PM
Oxygen 8 not showing up as Midi device anymore Chris A. MIDI 1 06-05-2006 07:45 PM
Mbox not showing in Aggregate Device Editor bluerockgod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-01-2006 08:05 PM
