MBox 3 sample rate
Can someone please confirm that the 24/96 sample rate on the MBox 3 is for the mic pres as well as SPDIF?? Cheers!
Re: MBox 3 sample rate
Anybody???
Your question doesn't quite make sense. The AD and DA converters in the Mbox 3 go up to 24/96 regardless of whether it's preamps, line ins, or whatever. Meaning you can record something at 24/96 whether it's from the preamps or line ins.
Thanks for the reply anyway! |
You can download the manual from the website. It seems pretty straightfoward to me. This is a quote from it, in the features section:
"24-bit A/D and D/A converters, supporting sample rates up to 96kHz." I'd be curious to know what interfaces you've seen that have the limitations you mentioned. The limitation of adat on some interfaces is a limitation of adat, not the interface. Some interfaces add SMUX capability to get a higher sample rate, but that's not the same as standard adat. Anyway, all indications are that this is a converter (analog to digital, digital to analog) that goes up to 96k. |
PT LE max sample rate is 96k - you can SPDIF thru the mbox at 96k without touching the AD-DA converters in the mbox (so the mbox "supports up to 24/96") - the AD-DA converters can be 16/44.1 & they can still claim the mbox support up to 24/96! That's why I'm just being cautious - I want a 2 mic pre box that does 24/96 - every other option I've found is firewire.... I see enough adspeak at work to know that if its not stated explicitly chances are I'm being duped. |
sample rate issue with new Mbox (3rd gen) | indoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-22-2011 08:28 PM |
PT LE 8 Mbox 3 Pro sample rate help. | benherron.rrr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-20-2010 01:35 PM |
MBox 3 Pro In PT9 Sample Rate | cybrgost | Pro Tools 9 | 4 | 12-04-2010 08:25 PM |
MBox Micro Sample Max Sample Rate Only 48 kHz? | Joe Sciacca | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-07-2008 12:52 PM |
mbox 2 pro and sample rate not working at 88.2 | dekits | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 21 | 03-11-2008 10:54 AM |
